Question about Toshiba SD-4800 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
Drawer wont open when prompted. gives a message of loading when playing, wont play
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Posted on Dec 07, 2009
Toshiba SD-K740SU player won't play dvd
Clean the optical pickup unit, by inserting a lens cleaning disc in to the system. If it do not help you, the optical pickup unit should be replaced. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts. You can gather all details. Sometimes, click open the adverts' by the side and bottom of each post might give you more details.
May 26, 2012 | Toshiba SD-5980 DVD Player
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
Cannot get cd drawer to open. LCD says load, but
take the top cover off and have a look at the dvd,which has probably come off the tray. it is jammed for some reason
Aug 18, 2009 | Toshiba SD-K760 DVD Player
My LITEON 5045GDL+ dvd drawer wont open.
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommend replacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
Jun 18, 2009 | Televison & Video
The dics tray is not opening
the same thing happened to me and I switched off at the plug had a cup of coffee and switched back on and the drawer opened and no probs since
Apr 15, 2009 | Toshiba SD-4800 DVD Player
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Feb 26, 2008 | Toshiba SD-V394 DVD Player/VCR
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Toshiba SD-4800 DVD Player Logo
380 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
