Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Starter keeps breaking on mw 01 wideglide
Starter keeps breaking on 01 wideglide replaced clutchbasketit hasbroke agin along with starter HELP
  • 116 Answers
If when you changed your clutch basket did you replace the hub bearing if so id be looking at the inner primary bearring and when you reinstall the starter make sure your mounting surface is clear one wire under oneside of the starter could cause your prob but more likely one of those 2 bearrings
Posted on Dec 31, 2009
How do i replace kitchenaid superba microwave torsion spring
This is tricky if not done in correct order real easy to break the plastic door frame I will try an explain best I can there is a vent cover between MW door and oven door remove on the MW bottom frame there is a tab on each side with a small screw remove screws you can now pull MW forward won't move very far now the plastic piece that connects to door look up at bottom remove these 2 screws it will be at an angle I use a small speed wrench with a phillips bit okay all this is loose now open the MW door towards top there are 2 holes inside each is a phillips screw use a skinny screw driver hold the door tight it is spring load the frame part with glass will try to slam forward door should now be free usually only one spring is broken change both they are not the same different part numbers take a picture first before trying to remove you will eventually figure out that you have to put in hole at one end and thread thru to the other end then twist in place to lock now be careful if you slip real easy to break inner glass once you figure all this out put the door back in the exact opposite order starting with the door screws first you will now find out the door has a high spring load i usually mate the door to the frame and secure with tape after door is on then do the 2 screws on bottom of plastic frame do the sequence backwards you will break this piece, best i can do yes a lot work but remember I do this about 3 times a week I suggest you think about paying an appliance repair company to do this reason being that plastic piece i keep harping on is roughly 100.00 to replace which negates most savings by doing it your self hopes this helps good luck
Feb 16, 2015 | Ovens
1985 fxst starter problem
Hi Anonymous, try replacing starter relay. Good luck
Jul 02, 2013 | 2000 Harley Davidson FLSTC Heritage...
How to replace a voltage regulator on a 2007 Dyna Wideglide?
I haven't replace a voltage regulator on the later models but it should be the same as the earlier models. First disconnect the battery. There are three wires on the regulator. Two go to a plug that goes to the alternator in the lower left front of the engine. Unplug the old regulator and plug the new one in. The third wire is slightly larger in diameter. It goes back to either the positive battery post, the starter, or the main circuit breaker. Some people cut this wire and put a **** connector on the wires to keep from having to run the wire along the frame and to the battery. I never do this, it's asking for a problem later on. Follow the wire along the frame to wherever it connects to and disconnect it. Route the wire from the new regulator along the same route to the connection point. When you mount the regulator to the frame, make sure the regulator is well grounded to the frame. I usually put a "star" type lock washer between the frame and the regulator.
Good Luck
Steve
Aug 11, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
05 wideglide starter will not turn over but bike will start on a push start. replaced starter relay and no better
Look at the end of your starter from the right side of the bike. You'll see a pentagon shaped plate held on with there small screws. There's a single wire connection at the top of the plate. Unplug the wire and connect a test light or a volt meter to the wire. Turn on the ignition switch and press the start button. The test light should light up or the meter should show battery voltage. If it does, your problem is in the starter. If it does not, your problem is electrical. This wire comes straight from the starter relay and it energizes your solenoid.
Good luck
Steve
Aug 24, 2010 | 2000 Harley Davidson FXDWG Dyna Wide Glide
I replaced the starter fuse but every time i try to start the car, It blows out agin and again
Sounds like the starter is pulling too much current, probably because of a shorted winding. Sounds like starter needs replacing. You could remove it take it to Autozone for testing.
Charlie
Oct 01, 2009 | 1997 Dodge Stratus
I have a problem
You need a new starter relay. It is located in the black box on the rear wall of the forward compartment. It is the one with the 2 red starter cables going to it and a brown and black wire coming off of it.
Jun 25, 2009 | Yamaha 12V Air Pump
I couldnot remove pagemaker 6.5 from mw pc
you can downloding the ccleaner software
that software can
easle remove your software that not effacted
thane repari that software and than try agine
Mar 25, 2009 | Adobe PageMaker Plus 6.5 for PC
My 01 chevy silverado 1500 won't start MOST of the time.
There is a clutch safety switch under the dash. When you press the clutch it presses the switch. You might try replacing that and see if that fixes your problem. This would cause it not to start and everything would still come on.
Jan 26, 2009 | 2001 Chevrolet Silverado 1500
Lands Phones Logo
87 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
