Question about Maxtor DiamondMax Plus 8 40GB 7200rpm 133MBps Ultra ATA/133 (ATA-7) Ultra ATA/133 (ATA-7)... (6K040L0FT) Hard Drive
I have used my maxtor 8 as a slave. I now wish to use it as a normal drive. My attempts to install XP produces an indication that NTLDR is not present. I have managed to start the installation program but this reports a failure. What can I do?
  • 55 Answers
Double check the jumbers on the drive that it is set to master and not slave.
After that make sure your Bios has it set as "primary" disc / hard drive. If the old drive is still present, make sure it is set as secondary disc / hard drive.
Also make sure you have the boot order set up. Maxtor 8 should be set as boot first than the other hard drive.
All of this is in your BIOS boot up. Try hitting the "pause" key as it is booting up. When it pauses you will be able to see what key to get into the bios.
Sometimes the key to get into bios is the "delete" key or one of the "F" keys. But that will vary.
Posted on Oct 04, 2009
  • 657 Answers
Restore NTLDR and NTDETECT From the Windows XP CD
  • Start the Windows XP Recovery Console:
    1. Insert the Windows XP installation CD into the CD or DVD drive.
    2. Restart the computer.
    3. While the computer is starting, repeatedly press F12 every 3 seconds to access the one-time boot menu.
    4. When the one-time boot menu appears, press the Down Arrow to highlight the CD-ROM option that appears, which is one of the following options: Onboard CD-ROM Drive or Onboard USB CD-ROM Drive.
    5. Press Enter.
    6. When the computer boots to the CD-ROM drive, press R to enter the Recovery Console.
    7. If prompted, select the number corresponding to the Windows installation you want to repair and press <Enter>.
    8. Enter the Administrator password, if any, and press <Enter>.
  • Type map, and press <Enter>. Make note of the drive letter assigned to the optical (DVD or CD-ROM) drive.
  • Type copy x:\i386\ntldr c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  • Type copy x:\i386\ntdetect.com c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  • If you are prompted to overwrite the file, type y, and press <Enter>.
  • Type exit and press <Enter>.
  • As the computer restarts, remove the Windows XP CD.
  • Posted on Oct 04, 2009
      Scholar:
    • 82 Answers
    If you had it set to slave status, there is a jumper on the drive controller next to where the cable plugs into. that jumper needs to be set to the correct position. typically there are 3 jumper positions Master, Slave, and Cable Select. If this is the only drive in the system, you can set it to master or cable select position. If there are multiple drives, then every drive needs to be set to cable select.
    The diagram on the drive label should tell you which jumper is cable select position.
    Dual boot xp with windows 8
    No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
    OR in the current scenario you've to do much technical work using third-party tools.
    Feb 27, 2014 | Microsoft Windows XP Professional With...
    How do I get technical support. I am experiencing a NTLDR is missing error.
    Here are a few things to try:
    1. Make sure the CD/DVD drive is empty.
    2. Make sure there are no USB Keys/Flash Drives/Pen Drives plugged into the computer.
    3. Reboot the computer after making sure no extra disks or external storage media is plugged in.
    4. If you're running Windows XP - attempt to fix the NTLDR error by booting the the OS CD and running the recovery console. Once in the recovery console, type:
    Copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
    If it asks you to overwrite the files say "y".
    5. If the system still fails, then you may need to slave your hard drive to another computer to get your data recovered. After doing this - you may need to reinstall or perform a repair install of the Operating System using the Windows CD.
    Nov 14, 2011 | HP Compaq Presario SR1230NX (PJ518AA) PC...
    Take Two: I have an older Maxtor Hard Drive
    Connect it on hardisk enclosure then removed all pins
    then connect it usb this serves as an usb flashdisk
    Nov 12, 2009 | Maxtor Hard Drive
    My vista computer doesn't recognize my maxtor one touch 4 external harddrive...it doesn't recognize it on my xp either how can I fix this...I have a lot of stuff backed up on this and it is less than a...
    HI,
    What I would suggest, is to take the drive and install it as a slave drive. Make sure your pin settings on the drive are set to slave, and your main drive is set to slave. Then XP and Vista will recongize it so you can pull the data off it, then reformat the drive and see if you get any errors.
    Good Luck
    Mark
    Oct 27, 2009 | Maxtor Hard Drive
    I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
    For use as slave there is no jumper connected. (Master on/slave off0
    Oct 04, 2009 | Maxtor Hard Drive
    Installing old maxtor HD on newr pc, have to change it to a slave
    J50 is the one furthest from the power connector. To make it a slave remove ALL of the jumpers.
    Jul 26, 2009 | Maxtor Hard Drive
    Maxtor PLUS 8 7200RPM IDE ATA 133 40GB hard drive. Do i need jumpers and software for the install of this harddrive and if so here can i get. Thanks j
    are you mounting it as the only drive or with another one... if you are mounting it as a slave usually you don't need a jumper... the jumper setting will hopefully be on the sticker.
    xp and up will autodect the drive..
    Jan 23, 2009 | Maxtor Hard Drive
    What new HDD will match my Maxtor DiamondMax Plus 8?
    Mark,
    You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
    Dec 29, 2008 | HP Compaq d530 PC Desktop
    Dell Dimension 2400 - Adding second HD
    set the jumper on the maxtor to cable select and see if that fix's things ?
    Nov 29, 2008 | Dell Dimension 2400 PC Desktop
    Pin settings
    There are four Jumper settings on a Maxtor:
    (got it from http://www.techspot.com/vb/all/windows/t-32378-Windows-XP-Home--No-boot-device-help.html)
    posted by by mr.smit:
    "The 2nd row, is for DS(Master): only 1 drive in PC, or the drive that you want to boot up from.
    The 3rd row, is CS Enabled: Cable select, the computer desides wich harddisk is master and wich one is slave
    The 4th is cap limit: windows cannot run on harddisks that are to big, like 300gb, so putting jumper on cap limit (capacity limit) makes it smaller for windows to use it.
    The 5th row has no use, or i don't know what it does, either of that 2."
    I would like to add about the DS (Slave) setting. It is used if there is another drive present on the system which you want to boot from. It will become a spare Hard Disk.
    Here is a picture of a maxtor drive indicating where to find model number and jumper settings.
    http://xboxdrives.x-pec.com/images/maxtor-drive-model.jpg
    Nov 19, 2007 | Maxtor Hard Drive
    Computers & Internet Logo
    269 people viewed this question
    Top Maxtor Computers & Internet Experts
    Computer Links
    Rick Arnold
    terminalcon
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
