Question about AviStart 5303 2-Way Security / Remote Start System
Where to hook up the remote start activation wire?
  • 30 Answers
There is no need to hook up the remote start activation wire. That wire is for testing the system after it has been installed.
Posted on Oct 09, 2009
I am hooking up an alarm with remote start on my Hilux 22r. I need to know which wires do what on the back of the key start switch so I can tap into them. I need acc, on and start
ACC is on when switch is in ACC position - usually the first stop.
Neither ON or START is active.
ON is the ignition - usually the 2nd position.
START is active when u push and hold the switch past ON. ON will also be active.
Feb 18, 2015 | Cars & Trucks
Do i have to hook up the tach wire and the activation wire and the neutral safety wire?
The activation wire is for external activation. You have remotes so, NO.
If this is an automatic transmission, you can ground the neutral safety wire or, wire the toggle switch with ground. Tach wire is only necessary with manual transmission.
Mar 04, 2013 | Remote Start with Two 4Button Remotes ...
I need to know how to wire a led scanner to an avital 5303. The light has a red pos, black neg, and yellow that says brake. i want it to come on when the alarm is activated
Forget the yellow wire. Its for wiring WITHOUT an alarm. Connect the red to a fused 12 volt and the black to the orange "ground when armed" of the Avital 5303.
Jan 21, 2013 | AviStart 5303 2-Way Security / Remote...
2001 jeep grand cherokee /viper 5101 rs with keyless entry all wires are hooked up properly as far as im concerned but remote start will not activate i have a 7 flash diagnostic code
I'd say the easiest thing would be to stop being a lazy tw@ and get into the vehicle with a key as normal. Come on, lose some wait...
Mar 11, 2011 | Remote Start System
Spy 5000m remote start issues
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
May 05, 2010 | Brand Remote Start/keyless/car Alarm Very...
I need to bypass my viper remote start system as I
Check ur battery take out any extra wire that hook up to the battery.The system should have no power to the Viper system.U should able to start ur car without the Viper remote.
Apr 21, 2010 | Viper Security and Remote Start System...
AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF RANDOM AFTER INSTALLATION NOT SET ON COLD START
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Jan 05, 2010 | Remote Start System
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
Python 1400XP remote start system
yes you are correct the learn procedure is done by a dei 555L or a 555G bypass module.your car should have one or the other installed on it. simply unplug it,it will be a three wire plug. then plug it back in and then by turning the ignition on and off it will relearn the code.
Dec 05, 2008 | DEI Python 1400XP Remote Start/Keyless...
AviStart 5303 2-Way Security / Remote Start System Logo
308 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Morgan Kane
Level 1 Expert
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
