Sensors need cleaning but I cant find them
Bin full indicator says full when it is not
The optical sensor or mechanical sensor is going to be above the shredder "teeth" just under the cover it is probably dirty with envelope glue, air alone may not be enough.
Posted on Dec 08, 2010
  • 68 Answers
It is most likely an optical sensor on the bottom of the motor assembly of the shredder.It should be shown in the operation manual.
Posted on Oct 05, 2009
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
Jan 16, 2014 | Scotsman Cooled Modular Contour Cuber...
Bin full light
The sensor build limestone residue during operation and needs to be cleaned off. The bin sensors are typically located on either side of the freeze platens and can be removed to clean. Turn machine off and unplug. Reach in past the water trough and freeze platen and you will see the transmiter and receiver plugged into the side walls. Gentlely work sensor loose and work sensor wiring out hole until you can get to sensors. Clean the two sensor with a clean cloth and with vinegar until sensers are clean. Reinstall, and plug back in and start unit. Bin sensor light should be out and should start.
Aug 24, 2013 | Scotsman Refrigerators
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
Can t get scotsman cme1656rs to start
problem was not the universal controller. The bin sensors are dirty and scaled up and gives the same indication that bin is full. find the sensors and clean the scale off and unit should start working again. Save the card, you will sooner or later probablly need it.
Dec 27, 2012 | Scotsman Refrigerators
We have a Fellows Pwoershred 2200SC that keeps showing the full bin light even when it's empty. Tried cleaning the eye near the feed area with canned air as per recommendation by a shredder maintence...
There are also sensors under the shredder head to indicate when the bin is full. You either have a defective sensors or a dirty one (clean with air).
Aug 29, 2011 | Fellowes 2200SC Shredder
I purchased a koldfront portable icemaker KIM202W from living direct (online) in Austin. The ice full indicator light stays on and will not allow for refill of water. I have read the manual, turned off the...
have you checked to see if there is a ice full bin sensor that may be dirty, iced over, or something similar - there has to be a sensor that will tell the system to shut off when the bin is full and it's got to be blocked by something - Good Luck - Eric
Oct 02, 2017 | NewAir Kitchen Appliances - Others
The "Bin Full" indicator light
There is a sensor in the bin area of the machine that is faulty. If you have cleaned the bin area completely and still have that problem then the sensor is bad and will have to be replaced. Look on the manufacturer website for the replacement part.
Jul 11, 2011 | Quartet gbc 4220S Shredder
The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Mar 26, 2009 | Fellowes Office Equipment & Supplies
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Fellows Powershred c-120 c indicator lights
your bin full sensors are dirty or broken to clean access bottom side of shredder head and look for a set of screws on each end of the paper throat. There you will see two little bulbs (bin full sensors) these have more than likely gathered paper dust and need to be cleaned with a Q-tip dipped in a little Isopryl Alchohol. This should solve your problem. If you have any questions just call us at 1-800-945-4545. A Customer Service Representative will assist you.
Apr 22, 2008 | Fellowes Powershred 120C-2 Shredder
342 people viewed this question
k24674
jasbo
jasbo
