Question about Cables Unlimited SWB-9000 2-port KVM Switch
How do I switch between computers with my KVM switch?
  • 557 Answers
Hit scroll lock key twice and then the up arrow. That is the hot key command. There is also a manual switch on the unit.
Posted on Oct 04, 2009
How to connect 2 computers to a dlink 4 port kvm switch?
The unit comes with all the cables in order to connect up to four computers to one KVM switch. If you're only using two computers, then you'll only need to connect one computer to Computer 1, and the second computer to Computer 2. The KVM will recognize that only two devices are connected, and generally skip the inputs for computers 3 and 4 until they have a device connected.
Feb 26, 2011 | D-Link DKVM-4K (dldkvm4k4port) KVM Switch
I just buy a new computer and go to hook up my KVM switch that I was previously using and was working flawlessly. All cables are connected (KVM PS2) except the KVM video cable to computer # 2. So I'm...
I would look first at rep;lacing the cable itself, KVM's usually last a very long time. Cables can break down after awhile. The easiest way to check is to try the other cable on the new machine., or a pin could be bent on the cable.
I would look at those two things first before the KVM. IT is possible that the KVM may not support the new machine, depending on how old it is.
Jan 18, 2011 | Belkin 2640-FTUA 2-port KVM Switch
New IOGear GCS632U KVM inop
First, disconnect the KVM switch from the computer(s). Disconnect also the keyboard and mouse from the KVM switch, including speakers (if there is). Leave the KVM disconnected for 5 minutes.
Before you reconnect the KVM switch, make sure that the computers are turned off. Re-connect the KVM switch to the computers, and then reconnect the keyboard and mouse.
Turn on the first computer, followed by the second one. If you are still not getting any light indicator, then the KVM switch is dead.
You may contact IOGEAR through 866-946-4327.
Thank you for using FixYa!
Jun 08, 2010 | IOGear GCS632U 2-port KVM Switch
Have a GCS634U KVM that keeps failing to switch. acts like it lost the keyboard
This GCS634U was designed to work with USB keyboards and mice.
First, you need to make sure that your using a direct USB keyboard (no PS/2 to USB adapter).
Second, connect the keyboard directly to the computer and make sure that it's working correctly.
Third, check the connection between the KVM switch and the computers. Try to connect the USB cables of your KVM into different USB ports of the computers.
Last, try to use different USB keyboard to see if the issue is the KVM or the keyboard.
Try to power cycle the KVM switch. Disconnect the KVM from the computers and make sure that there's no even one cable connected to the computers.
Leave the KVM switch disconnected for 10 minutes, then plug it back in. Reboot one computer first and wait until it's fully rebooted. Turn on the second one untill all computers are fully booted up.
If same problem occur, then you need to contact IOGEAR and have them RMA the device.
Thank you and good luck!
Nov 12, 2009 | IOGear GCS634U KVM Switch
Euromax code box for virgin midia
Check that you are getting power to your StarView SV211K 2-port KVM switch. Try disconnecting the power, and then reconnect it, to "reset" the KVM. Check all the cables from port #1 on the KVM to computer #1. Check all the cables from port #2 on the KVM to computer #2.
Check all the cables from your Keyboard/Video/Mouse to the KVM.
If you still have a problem, disconnect everything from the KVM,
and connect the Keyboard/Video/Mouse directly to computer #1,
to ensure that it works *without* involving the KVM.
Oct 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need drivers for xp and vista
Most KVM switches does not have a driver. Because these devices are simply Plug-n-Play and does not require any driver installation.
What you need to do is to check the system requirements for every KVM switches before purchasing it.
Here's the fact:
- PS/2 KVM switches are designed for PS/2 computers keyboard and mouse
- USB KVM switches are designed to work with USB. Meaning, if you're going to use an adapter (PS/2 to USB), there's a big chance that your KVM might not work correctly.
- Most KVM switches does not work properly with docking stations.
- KVM switches are tested to work with wired keyboards and mice.
- You have to make sure that everything is properly connected to the computers if you want your KVM switch function properly.
- Lastly, update the USB driver of your computers (XP and Vista).
- Most KVMs has a firmware upgrade that you may find in manufacturer's Web site.
Mar 08, 2009 | Computers & Internet
KVM unresponsive
Greg,
Try swapping the KVM cables from the 2008 computer into the Vista computer and see if the problem follows the 2008 computer. This KVM gets the drivers it needs from the OS and the IOGear web site does not show any support for 2008.
Jan 16, 2009 | IOGear GCS632U 2-port KVM Switch
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Kvm switch won't stay on second computer, switches back
You might try disabling any power saving schemes in use on either computer. The KVM (I believe) gets its power through the ports and one computer may be shutting down power.
Aug 31, 2007 | Belkin F1DL102P 2-port KVM Switch
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
Cables Unlimited SWB-9000 2-port KVM Switch Logo
416 people viewed this question
Top Cables Unlimited Computers & Internet Experts
Ed Mac
1860ph
Level 1 Expert
Are you a Cables Unlimited Computer and Internet Expert? Answer questions, earn points and help others
