Question about Juki Sewing Machines
I have a Juki 98E and the feed dogs are (I believe) in the up position, and when I put the lever in the down position and then start to sew it "clicks" over the the up position. The lever is pointing to the left. Do you know what could be causing this?
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
bargainbox
  • 1388 Answers
SOURCE: Brother Super Galaxie 2100 - Feed dogs will not lift
Remove needleplate and clean out the built up lint between the teeth of the feeddogs.
When moveng from Feed Down to Up, rotate handwheel one revolution to re-engage.
If neither is a problem and your manual is of no assistance, take it to a service centre to check it out and quote.
Posted on Aug 19, 2009
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Posted on Oct 07, 2009
Feed dogs won't raise on tl-2010q after lowering them
Hello Lisa Girodat
Referring to the manual, pg 28, make sure that the feed dog position lever has been activated. The feed dogs should come up after the first full stitch.
If you do not have a manual, you can download it for free here: https://www.juki.co.jp/household_en/pism/img/tl2010q/download/Inst_2010Qi.pdf
Please let me know how this works out for you.
Happy Stitching
Sewingirl/
Mar 12, 2017 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Why is the needle not moving or feeding fabric but motor is running
the needle only sews,, it's the feed dogs in the needle plate area that feed the fabric thru the machine, if the feed dogs are in the up position then the machine will sew, if the machine is not sewing then the feed dogs need to be checked to see if the feed dog lever is up or down, look in the manual to see where the lever is and check it, if the lever up the then feed dogs will need to be checked to see if there is something's wrong with them at a sewing machine repair shop.
Jul 31, 2014 | Janome Sewing Machines
Esante baby lock ESe2 dog feed won't feed material.
check to see if the feed dogs lever is in the up position for sewing, if not move the lever to the up position, if the feed dog lever moves and it doesn't make the machine sew, then the feed dogs need to be checked.
Nov 19, 2013 | Sewing Machines
I have an Elna 2730. the feed dog is not transporting the fabric anymore and the needle just keeps stitching in the same place. is it broken or just needs adjusting?
if you have a manual, look to see where the feed dogs are, if the lever for the feed dogs is in the up position then the machine will sew a straigh stitch
if the feed dog lever is in the down position then it will only stay in one spot,
if you try to push the lever up and it will not stay or stays and will not sew then the feed dogs need to be checked
Oct 09, 2013 | Elna Quilter's Dream 6003Q
Kenmore model 17821
if you have a instruction manual for the machine, then check to find out where the feed dog lever is, and check to see if the feed dog is in the up position to sew or in the down position, if the feed dog lever is in the up position and will not feed the fabric, then the machine need to be check to see what's wrong with the feed dogs.
Jun 20, 2013 | Sewing Machines
Feed Dogs
when the feed dogs are in the up position the sewing machine
will sew
but when the feed dogs are down postion it will darn
try the feed dog lever again if you can move the feed dog lever and
the feed dogs respond going up and down then you know that
the feed dogs are working and are not broke
but if they do not respond then they need to be checked to see what's
wrong with them
Oct 23, 2012 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
Feed dog is stuck
May 07, 2007 | Singer 2662
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
