Question about RTO PasLode 900420 Impulse Framing Nailer
My finish nail guns, 16 ga won't fire.
I have three paslode nail guns that all have the same problem, they all make the noise but won't fire the nail. Help, I don't want to put up casing the old fashion way.
Thanks,
Leonard
    Problem Solver:
  • 12 Answers
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Posted on Oct 04, 2009
I am using senco gas in a paslode 2nd fixing nail gun. Is the senco gas 'bad for' my gun in any way as i am having a few firing problems
You can use most gases in your gun, but paslode is the best that's why its more expensive. Try warming the gases in your pocket that sometimes helps.
Dec 17, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a paslode nail framer 900600. the problem i have is the same after 3 exchanges. The gun will stop firing. i have oiled it, replaced gas,etc. the hammer simply will not come down to force the nail...
It may be as simple as making sure the spark plug lead is in the spark unit all the way.( Black box in the handle). Good Luck!! If you get stuck call Adelaide Nail Gun Repairs. They may be able to help you over the phone.
Oct 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode shoots a few nails and quits
try a new battery m8 when they have been used fir a while they wear out at the catch and when u fire the nail gun the battery works its way out enuf to stop it making a good contact. Hope this helps.
Aug 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Jun 05, 2009 | Dewalt D51256K 16 gauge finish nailer kit
I have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
Mar 23, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO PasLode 900420 Impulse Framing Nailer  Logo
1,311 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
