Not draining - fill up and washes fine... I get
Not draining - filsl up and washes fine... I get beeping noise and PU letters come up on screen, like its got a blockage?? Can I do anything myself?
    President:
  • 1,304 Answers
Yes you can clean out the pump
Posted on Oct 05, 2009
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
I have a stackable Kenmore washer and dryer When I start the washer it will fill up and try to start then it will make a beeping noise and drain then it will beep again then stop I tried to switch cycles...
You have a clogged drain line their should be a plastic filter inside the washer located on the main drain line remove the plug clean filter and snake hose if ness. Make sure you have a container to catch water if not drained all the way
Jan 15, 2014 | Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
I have a whirlpool front load washer its fills with water and then it wont wash then it will drain the water and start beeping with the letter F on the panel
When a unit fills then drains it could be signaling that there is a bigger problem like a problem in the main circuitry the best thing to do is to higher a professional to come out and take a look at the circuit boards. I know it's not a quick fix answer but its better to have it checked out then that much water end up going everywhere.
Sep 26, 2012 | Frigidaire GLTF1670A Front Load Washer
When washer starts to wash it beeps and flashes the letters FH.
Hi
Error FH means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 17, 2011 | Maytag EPIC MFW9700S Front Load Washer
Our simpson washing machine is not spoinning and the letters PU flash on the electronic display panel.
PU is pump fault. Usually caused by a blockage. Machine will not spin until all water is drained
Thank You
Sep 09, 2010 | Washing Machines
My washing machine is beeping and displaying PU on indicator
PU stands for drainage problem and so we our checking the pump!!
Dec 08, 2008 | Washing Machines
F H beeping
ck fill hoses at rear connection and inside fill valve for debris..also be sure both faucets are fully on and there is sufficent water flow through both to washer be sure drain hose end is 30-36 inches from floor and fits loosely in standpipe ..allck ok then replace flow meter ..remove top on left side small round object with hose in each end 1 end goes to dill valve other to dispenser..flowmeter ckd for water flow into washer
Nov 01, 2008 | Whirlpool GHW9100L Front Load Washer
Kenmore model# 110.26892690
Sounds like the fill valve screens or fill hose screens need cleaning or replacing.Also if you are using burst resist hoses braided steel type some have check valves that if are defective may cause a no fill.
Oct 09, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
