Question about Bissell 12005 Spot Bot Handheld Vacuum
My SpotBox was working fine and I had to empty the
My SpotBot was working fine and I had to empty the dirty water and put new cleaner in and moved to a different spot and it won't work now even the light that shows it it plugged in to electric won't work. Please help....ncarr@dragonbbs.com
  • 13 Answers
Have you checked for hair clogs it is over heating? the machine might shut off due to over heating.
Posted on Oct 04, 2009
My Bissell Spotbot leaks dirty water
Zupernoc... I was having the same exact problems with my Spotbot Pet that you were having. I ordered the duckbill gasket (1.39 from bissell.com) and so far, so good! Thanks so much for sharing!!! And just for the record...not only was there no duckbill gasket on the unit when I purchased it, it's not even listed in the owner's manual as being part of the unit. Yet if you search for replacement parts on Bissell parts, there it is. Strange! Again, thanks for sharing. Saved me from trashing the thing and purchasing something new.
Dec 09, 2011 | Bissell 1200A SpotBot Pet Robotic Vacuum
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Leaking rusty water
Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
Gasket is about 2 bucks available from Bissell.
Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Not Sucking the dirty water
It seems that when you emptied the recovery tank it has not been placed back proper.
please make sure it is sealed else you will loose suction
Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
It is leaking water from the bottom
I had this problem, and after some research found out I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
I purchased this gasket from Bissell for 1.39 and the suction is night and day. No more leaks. I purchased my SpotBot Bissell new at Target, so I have no idea where the black gasket went.
Jul 07, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Clean the spot bot hose, it looks dirty.
My hose was filled with black mold, nearly from end to end, because I didn't clean it properly a year ago, which was the last time I used it. Here's how I got every speck of grime and mold out of the hose, and brought it back to looking brand new!
1. I placed the Spotbot on the counter on one side of my deep utility sink.
2. I unwrapped the hose from the body of the machine and held the mouth of the hose low, close to the sink drain.
3. I ran the water until it was scalding hot, and put the hose mouth up to the stream, keeping it low. I filled it for 3 seconds.
4. Then I poured spashless bleach down the hose mouth for a 2-3 second pour. Add more water if needed.
5. With a portion of water in the hose, I swung it back and forth, moving the bleach water all over the affected areas.
6. I continued to fill the hose with water and bleach(2-3 times), until I had a 1.5 inch reservoir in the dirty water basin to act as a suction plug.
7. I plugged my utility sink, and filled it with 3 inches of hot water, which I used to continue to fill my hose and to push out the air bubbles.
8. When the hose was full from end to end with bleach water and no air bubbles, but the reservoir remained at 1.5 inches full, I filled a plastic jar with 3 inches of water (for stability), and pinched the mouth end of the hose together upright into the jar. I placed the jar directly across from the Spotbot on the counter, on the other side of the utility sink. This means each end of the hose is elevated, and the body of it is hanging in the utility sink.
9. I left it like this all day and overnight. 22 hours later, I returned and the hose was pristine! I backwashed the hose and the dirty water reservoir out 4 times and hung the hose over the faucet to dry.
10. Hope this helps you!
Jun 21, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Dec 02, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
SpotBot: all lights flashing!
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
Aug 07, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell 12005 Spot Bot Handheld Vacuum Logo
121 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
