THE FAN OUTSIDE IS RUNNING BUT HOT AIR IS COMING OUT THE VENTS
  • Johnny
    Johnny May 11, 2010
    can you hear the compressor ?
    President:
  • 3,433 Answers
In other words, A/C isn't cooling. Is the compressor running in the outside unit where the fan is? In either case, you will need a technician to look at it. It can also need asome refrigerant charge and leak detection. Good Luck, Ned
Posted on Oct 04, 2009
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
98 caravan outside air always coming in
Put the vent on inside air circulation,not fresh air,then no air will come out.
Dec 03, 2012 | 1998 Dodge Caravan
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
My Sony Vaio VGN-CR320E turns itself off all the time. I have already formatted it, but the problem continues... What can I do?
IS it getting hot. Check the fans. It'll shut down if the fans aren't running and everything gets to hot. You might be able to use compressed air and blow out your vents and fan blades. Dust builds up and limits air flow causing extra heat, and then shut down. IF your running your laptop on your lap, make sure your not covering any vents or air flow. Its easy to do and not realize it.
Feb 18, 2011 | Computers & Internet
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
I came home house was hot went outside to check unit and fan wasn't running and smelled hot. My model # uacc-036jas. Is this a simple do it yourself fix or do I need to call service person
no fan was compressor running is there air coming out the vents ? do you know what a contactor is manuallly press it check the nreaker. 2 breakers one for airhandler one for condensor...
Sep 22, 2010 | Ruud Heating & Cooling
Air not circulating through vents
is the unit running outside? did you check the breaker? Ruud units often times will have a reset bitton on the outside unit to the left of where the freon lines connect. It is a high pressure switch if it comes on when reset make sure the coil is clean and the fan runs(outside)
Sep 20, 2009 | Ruud UBHC Air Conditioner
Air feels cool, but not blowing enought air
I worked at a Dodge dealership for a while and 9 out of 10 times this is due to the recirculation door being broken, allowing hot air from outside to enter the cab of the truck. The dashboard will need to be removed to access the area.
Sep 18, 2009 | 2006 Dodge Ram
AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Aug 01, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
