Question about Sony CPJ D500 Multimedia Projector
The Projectors can nos display de image completely
The Projectors can not display de image completely on Vista PC
    Sergeant:
    Champion:
  • 231 Answers
Change the display resolution
Posted on Apr 13, 2010
On startup error 1962 no operating system found
Pasos para hacer bootear Windows:
-apagar el equipo
-encenderlo y presionar constantemente la tecla F1 para entrar al BIOS.
-dentro del BIOS nos vamos al sub-men? Startup y lo configuramos de la siguiente forma:
***Startup***
*Primary Boot Sequence
*CSM: [Enable]
*Boot Mode: [Auto]
*Boot Priority: [UEFI First]
*Quick Boot: [Enable]
*Boot up Num-lock Status: [On]
add image in the mode perfect.
May 21, 2014 | Lenovo IdeaCentre K450 57315522 Desktop PC...
Reistalar programa original do hp netbook 1000
Sinto muito, mas este nao e um site warez ... Nos nao damos as chaves de ativacao ou codigos de acesso.
Jun 26, 2012 | HP Mini 1000 Netbook
Hola mi copiadora es canon image runner 400s y me da un error de una llave con un codigo E051 PORFAVOR AYUDARME GRACIAS
En los equipos de fotocopiado o copiadoras es difícil que aunque yo te diga, a que se debe la falla tu la arregles, nos a pasado que los clientes meten mano a los equipos y los descomponen mas,te aseguro, que esto no es por molestarte, te aconsejo que llames a un técnico, especializado, siempre que tengas problemas importantes. http://www.copiadorasfandis.com
Mar 09, 2011 | Canon imageRUNNER 400S Copier
Hitachi CPS-220 is saying 'RGB is out of range' when connected to PC.
This would indicate that the display settings on the PC are outwith the acceptable range of the projector.
To solve this, right-click on a clear part of your PC desktop and select "Graphics Properties" (in Vista). You then need to adjust the display settings. That is a very old projector which will accept a maximum screen resolution of 1024 x768 pixels. Try changing that 1st. If it doesn't work, keep that screen resolution and also adjust the refresh rate in Hz until you get an image.
The native resolution of that projector is SVGA (800 x 600 pixels).
Feb 14, 2011 | Hitachi CP-S240 Multimedia Projector
Multiple reddish pink vertical lines going from
take the top cover off and look for the 3 lcd ribbon cables plugged into thr main board. it is a pain in the ****, but the cable must be completely seated into the things on the main board. there should be little brown tabs on the connectors on the main board that you flip up or down, then make sure all lcd cable are pushed all the way in.
May 14, 2010 | ASK Proxima DP6860 Plus Multimedia...
Auto sync appears to not work properly
The projector does not recognise a vista display res. Change the pc to the native res of the projector for best results
May 19, 2009 | BenQ PB8250 Multimedia Projector
Manual de netbeans en espa?ol que sea facil de entender para laguien que nos sabe nada,
La mayoria de las paginas en el sitio de netbeans no se ha traducido a espanol. La unica que encontre es la pagina princiapal. Tienen un pagina de empezo rapido, pero solamente es en engles, portueguese, russian, y japonese.
Apr 16, 2009 | Computers & Internet
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
Sony CPJ D500 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
