Question about Kitchen Ranges
I just got a new kenmore gas stove and i cant get the burners to light is there a button that i have to press to get it working?
    President:
  • 1,304 Answers
No
but make sure your gas in on
Posted on Oct 05, 2009
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Kenmore Gas Stove gas takes a long time before it will come out
First, I'm not a Kenmore Tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
PS check youtube for: "Sears Kenmore Gas Oven Problems"
Feb 21, 2018 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Oven not working!
we're having the same problem.lol
Apr 10, 2009 | Kenmore Ovens
The stovetop locktop is on and i dont know how to turn it off
You want to charge me for a solution and yet you want me to tell you how I fixed the problem?
Yes I found a solution by myself and fixed the stove.
Mar 27, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
