Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W / TV Shut off and won't come back on after it has been on for a while
Have to unplug and leave it unplugged for hours before it will come back on
  • 1 more comment
  • kemical Jan 05, 2008
    MY HLN617W DLP WON'T COME ON. AFTER 3 ATTEMPTS TO START UP ALL THREE LIGHTS START TO BLINK AND THEN STAY ON. HAVE HAD TROUBLE BEFORE BUT THE SYSTEM WOULD EVENTUALLY COME ON AFTER UNPLUGGING IT. THIS HAS BEEN THE LONGEST THAT IT WOULD NOT COME (APPROX. 1 WEEK). IS THIS POINTING TO A BURNED OUT LAMP?
    THANKS IN ADVANCE FOR ANY INPUT.
    KEN
  • Jesseturk Jan 13, 2008
    I have the same problem. It worked fine yesterday and we turned it on today and it wont turn back on. There are three lights flashing and it makes the sound but it never turns on.
  • sikalimah Jan 16, 2008
    Turned the TV off for 20 minutes and it won't turn back on. Have had this problem in the past with the three lights on the front of the TV blinking and the manual states it could be a defective lamp. Generally waiting till it cools down helps and it eventually will turn on. Only way to stop the lights from blinking is to unplug the surge protector and plug it back into the wall. I replaced the $150.00 lamp last month but the problem is still there. I have also noticed that even with a new lamp, the picture is rather dark for several minutes when the TV is first turned on. I ordered the lamp from J & J as suggested by Samsung.
Had the problem with my 43 inch took it apart atleast 5 times loose connection on the light engine plastic wrapped wires had to be wiggled works for days also unplug the audio plug worked for me don't know if it was the vibrations or a power problem samsung gave me a # to talk to a technichian called them they don't talk over the phone 80 dollars for a visit samsung needs better support don't you think
Posted on Jan 02, 2008
  • 579 Answers
Get on the phone to Samsung at 1-800-522-7341 and start pushing. You have one of the dreaded N series that is full of problems. Even if you are out of warranty, they have been known to work with you.
Posted on Jan 01, 2008
Samsung HLN617w won't turn on
How old is the surge protector you used? Because they only last for so long and can absorb so many surges. I hate to say it but it sounds like your TV sustained a power surge.
Nov 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Get no picture or sound saying no signal
Reset the cable box,by unplug,replug it an hour later.So the box will upgrade it software.Should work after this.Not,there a HDMI cable,U use this cable.Replaced it.Don't work,after this,take another tv test the tv incomming signal.See,if the cable box is the cause.Not,than ur DLP tv Main Tuner board is dead,must replaced to solved this problems.
Apr 03, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My HLN617W dlp will turn on with no picture (sound is OK), then will seem to turn off, then back on again without me doing anything. After this ritual being repeated, the lamp and power lights will start...
The lamp is finished. Order a new lamp using the code on the side of the TV. Remove the lamp door on the back of the TV (4 screws) and then remove the lamp (1 screw). Have a look at the lamp... is it damaged? See my tips & tricks if you want to learn more about the lamp.
Mar 18, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I have a 42'' Samsung plasma tv and after turning on it turns off in about 8 minutes and keeps turn off and on.
do a hard reset its called by turning off, unplug from wall leave unplugged for atleast 2 hours then plug back in and turn on
Jun 30, 2009 | Televison & Video
Samsung 61" HDT5087S/HL
How old is the unit?
ever replaced the lamp?
Sounds like a major power supply failure
Hope you are under warranty
Samsung has lots of problems with this technology
Here is their phone for executive customer relations: 1-800-522-7341
Dec 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know tvtek@msn.com
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
TV randomly shuts off
when it shut off, are you able to simply turn it back on? or do you have to unplug it? also are any of the leds on the front on or blinking
Nov 29, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLP6163wx
when is the last time you changed the lamp ?  are the fans clean
Oct 15, 2007 | Samsung HLN617W 61" Rear Projection HDTV
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
78 people viewed this question
Jerry Greenberg
Jerry Greenberg
