Question about Panasonic Heating & Cooling
This is an older heater, which will not cut off to
This is an older Panasonic split system heater, which will not cut off to match the thermostat reading, we have no instructions with it. A number on the remote in A75C258 106M. The heater works well otherwise.
SpotBert
  • 231 Answers
SOURCE: panasonic split systems
Try here =>
http://www.partstore.com/Search/Model/Matsushita/Panasonic.aspx?
Posted on Dec 30, 2008
  • 59 Answers
SOURCE: programming a remote
i would take it to a dealer and have them program it for you it should not cost to much
Posted on Jan 02, 2009
  • 400 Answers
SOURCE: Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
Posted on Mar 05, 2009
  • 340 Answers
SOURCE: Remote control doesn't work on my Split System Air
try new batteries 95% of the problem
Posted on Jun 20, 2009
  • 81 Answers
SOURCE: Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
Older pictures of honey wells
Paula, remove the cover of the thermostat and look for a model number. The actual thermostat may have to be removed from the sub-base to find it. There may be either a long line of pins on the sub base that matches up with holes on the back of the thermostat when you re attach it....or there may simply be a 3" long ribbon connector that makes the connection.
Once you have the correct model number call Honeywell Customer Service at 1 877 841 2840 and work your way through the menu until you get to 'if you a homeowner push this number'. Once in touch with a live troubleshooter, they should be able to assist you in programming. You should know what kind of system you have, gas, electric or heat pump heat with central air.
You MUST have the correct model number BEFORE you call.
Nov 10, 2015 | Honeywell Programmable Thermostat Heater
When I turn on my heater it cuts off before it reaches the temperature it set for.
wonder if the thermostat is out of calibration? some older thermostats (mercury filled switch type) must be installed horizontally leveled. draw horizontal line with the aid of a level. align markers in base of thermostat to the drawn horizontal line. or you can try a different thermostat.
Oct 12, 2015 | Heating & Cooling
Fan will not cut off
Janet, the problem most likely is not in the thermostat. It is probably the fan relay on the circuit board in the furnace. Some furnaces have an individual fan control board, some furnaces have all the controls integrated within one control board. If your furnace is 20 years old or older, it could be the fan/limit control because at that time all furnaces did not come with a control board. If it is much older than 20 years, it is much more likely a stuck fan/limit.
Apr 12, 2015 | Honeywell Programmable Thermostat Heater
My Panasonic split system inverter is leaking water from the inside unit
condensate drain is stopped up and if older than 6 yrs, need to remove the unit and clean coil and pan with high pressure water
Mar 24, 2011 | Panasonic CW-1006FU Air Conditioner
Everytime i hook ipod upthe powere cuts off
Possible that the ipod is giving some errors like a high input which is not matching to the amplifier and so make the protection cut off.
Reduce the voltage of the ipod, connect the ipod using a cord that has a impedance matching circuit to the input of the amplifier.
if you are using the earphone output to the aux input it is a mismatch, so the impedance must be matched with a resistor network.... converting a low to a high impedance.
Sep 29, 2010 | Panasonic Home Theater System System
Removed honeywell thermostat from new home to install a new honeywell programmable thermostat. Couldnt get the new one to work so reinstalled the old one and it wont work. Checked breaker already, cant...
Do you have a model number for the new and old thermostat? Do you have a split system? This means you have a heater in the house and a condensing unit somewhere outside of the house. Let me know if you have a packaged unit or a split system and we can go from there. I might just be a blown fuse on you board, but I need to know what you have so we can start to trace things out.
May 11, 2010 | Honeywell Programmable Thermostat Heater
Ac doesnt come on. thermostat doesnt come on a oesnt have power
check main power. is it a package unit or split system? is it a digital t-stat. if so, does it have a display? check batteries, could just be a fuse
Apr 09, 2010 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Six wire hook up and new thermostat has only 5
Some thermostats have an extra terminal for an outdoor sensor which tries to anticipate the need for heating or cooling. If this option is not present, you will have an unused terminal which may have a shorting link to a neighboring terminal. Your installation instructions should mention this if the option is or is not included with your model. Also, heat pump systems vary in the system control voltage and not all thermostats and systems are compatible with the more common split system thermostat.
Oct 01, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
48 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
