Sears kenmore washer one year old top load is displaying a code of Ld what does that mean?
    President:
  • 1,776 Answers
The "LD" code or "long drain" has to do with the amount of time it took to drain the water. It's not only IF the water drained, but HOW QUICKLY it drained. The things to check are the drain line. Make sure it is not kinked or obstructed in any way. The next check would be the pump. Remove the hoses and use a flashlight to look into the suction port and make sure that nothing is clogging the pump (like the occasional stray sock, etc) and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If there are any damaged/missing blades or if you cannot get the impeller to spin freely, then the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Run a hot wash cycle with a 1/2 cup of vinegar also. This will help clean out any sludge buildup in the drain line. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 04, 2009
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Kenmore elite oasis top load error code Ld
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Calypso top load Kenmore washer. I get an LD code displayed and the washeer stops Any ideas ?
Although I haven't 'LD' in my list, I suspect that it indicates there is a problem with the lid/door lock. Either the locking solenoid or the lid lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 20, 2011 | Kenmore 24032\24036 Top Load Washer
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis code ld can you help
HI There
I want to say is Merry X-Mas and a Happy New Year. I have found what you need and hope this get's you in the right direction. Let me know how it went.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best Regards Richard
Dec 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ld code, will not drain, will not turn off
there is something stuck in your pump remove the back panel and you should check the drain pump the pump that is on the bottom left. good luck
Jan 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer displaying "LD" and constantly beeps
Sometimes the LD on certain machines can be decieving, It's possible that the error is pointing to a lid lock issue. I'm a sears tech but have logged of my work computer for the night so I can't look it up right now. I just happened to stumble on this forum. In all appliances there is a tech sheet hid somewhere. This will give you more information. On this model, if you press and hold anykey for 3-4 seconds, let it up for 3-4 second and do that 3 times it will show more codes and go into a test cycle. Don't worry you cant screw anything up in the controller. If you or anybody needs help on appliances you can drop me a line. I have been a Sears tech for 15 years and have seen a lot of stuff and learning more all the time. scottowa at hot mail
Dec 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
