Question about Lexmark X2470 All-In-One InkJet Printer
Can you please tell me how i can change ink cartridges for my lexmark x2470???
ginko
  • 19396 Answers
SOURCE: lexmark x2470 printer
You can get the User's Guide and other related documents here .
If you did not get the printer software cd, you will also need to download and install the drivers/software from here. Just chose your windows version.
Regards
Posted on Apr 02, 2008
wayneard
  • 1901 Answers
SOURCE: I cant figure out how to change the ink cartridges on my lexmark
On an X4850 the whole top of the printer opens up to reveal the cartridge carriers. Press down on the latch of each side to reveal the cartridges.
Here is a link to the User guide: X4850 User Guide It is described on page 94.
Posted on Nov 20, 2008
  • 684 Answers
SOURCE: lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Posted on Jan 19, 2009
  • 23 Answers
SOURCE: how to reset lexmark x4580 ink cartridge after refill.please help
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Page 99-100
Posted on Sep 27, 2009
SOURCE: refill ink for Lexmark X4850
I have a couple questions for you.
1. Is your cartidge 42 or 42A? The 42 cartridge will not work if you refill it. I learned that the hard way after paying to have it refilled and I got it home and it would not print. If you are using the 42A refillable cartridge, your ink levels will not reset. I called lexmark to ask them after not bieng able to find any answers online. He said that because I am using the 42A, it will print but will not register the level. The only downside is I have to keep an eye out for fading so that I do not ruin the printer heads.
I hoped this helped.
Posted on Oct 14, 2009
Replace ink cartridge
Perhaps the Lexmark X2470 User's Guide will be able to help you. Click on this link to download http://bit.ly/aeFv76. Scroll to page 42 for the instructions on how to install/replace the ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridge. Close the cover. Plug the printer back to power source. Thanks.
Oct 08, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have a lexmark x2470 printer.i would like to know whether it as one cartidge or two cartridges.please let me know if it is available in indaia
HI,
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor."
2. Click on "File" and then "Open" to select the color image file.
3. Click on "Image," "Mode" and then select "Grayscale."
4. Click on "Print."
This will print the image in gray.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
Printer Lexmark x2470 doesnt recognize the cartridge anymore.
Good day Sir, I suggest use the Solution Center. to open click start - programs or all programs - Lexmark Solution Center. find the maintenance tab. Maintenance tab help you install print cartridge and troubleshoot other ink problems.
have a nice day.
Jul 29, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
How do i change ink cartridge lexmark 2470
Hello friend,
If you give the middle section of your printer a lift you will notice it opens and inside you will see two slots: one for black ink cartridges and the other for color. Click down and lift the slot you wish to fill with ink and close slot (you should hear a click sound after slot is closed)
Mar 06, 2010 | Lexmark X2470 All-In-One InkJet Printer
Where does the ink cartridge go?
I have found a link for you which tell on how to replace a ink cartrdge in your printer. So you will be able to know that where does the cartridge go:
http://support.lexmark.com/index?page=content&id=HO3469&actp=search&viewlocale=en_US&userlocale=EN_ZA&segment=SUPPORT&productCode=LEXMARK_X2470&searchid=1266880591801
Feb 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
How do i change the ink on my lexmark x2470
Changing a print cartridge
Removing a used print cartridge
Make sure the printer is on.
2 Lift the scanner unit.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
3 Press down on the lever to raise the cartridge lid.
4 Remove the used print cartridge.
Good luck
Oct 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
How to install lexmark print cartridge
open up the top, the cartridges should center, pull the holders up, remove cartridges..be mindful to clean and re calibrate them after installing new ones.
if you need new drivers you'll find them here
Mar 11, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
