Question about AT&T 1725 Answering Machine
F1 CODE AND BEEPING ON 1715 ANSWERING MACHINE
4 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Answering Machine Problem
Try unplugging it and opening it up and gently blow drying it and try to avoid getting it too hot. Let me know how this goes and if it doesn't stop, then please let me know the make and model of the machine.
good luck
Posted on Jun 04, 2008
SOURCE: My folks (elderly) have a
I will advice you try to reset the device, once the device is reset, the problem should be fix, just reset the device to fix the problem.
Take care.
Posted on Aug 24, 2010
  • 225 Answers
SOURCE: I have an answering machine AT&T 1715, but
The 1715 user manual warns to only use power cord supplied with product. To order call 1 800 722-9125.
Posted on Dec 08, 2010
I have an answering machine AT&T 1715, but miss the cord power, could you please tell how many amps need and voltage too
Check the bottom of your answering machine. It should have the required power adapter listed. At least my answering machine had a nice clear label.
My 1337 AT&T answering machine uses the DAS-2 power adapter. This outputs 9V 780mA. Googling the adapter number I found that the Lucent 1715 also uses the DAS-2 adapter. (The Lucent is probably identical to the AT&T but check your machine.)
I found a used one here: http://cgi.ebay.com/LUCENT-TECHNOLOGIES-DAS-2-TELEPHONE-POWER-UNIT-9-VAC-/250730379907 . There may be other e-bay sellers with the item.
I hope this helps.
Dec 08, 2010 | AT&T 1725 Answering Machine
My folks (elderly) have a Lucent AS40/AT&T 1715 which for reasons unknown is displaying "F1" and beeping. What is the fix?
Take care.
Aug 24, 2010 | Lands Phones
F1-7 code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2010 | Jenn-Air SCE30600 Slide-In Electric...
I want to setup my Lucent AS40 answering machine
I had a problem recently when I looked online to find the manual for this model and a similar model, and thankfully I was able to solve the mystery and locate it. Even though the answering machine says it is a Lucent AS40, the correct user manual for it is the manual for the AT&T 1715. Once I figured this out, it was super easy to locate the manual on AT&T’s website... and sure enough, these two products are identical!!!
The user manual for the AS40 can be found at http://telephones.att.com/docMgt/public/art/161/1715_manual.pdf
I figured this out when I ran across an old article discussing a joint venture between Lucent Technologies (AT&T) and Philips Electronics. Apparently the two companies decided to merge together and combine their resources to develop technologically advanced answering machines. After the products were developed, each company marketed them under their name with a different model number, but both were selling the same thing! The reason we couldn’t find the user manual for the Philips model is because Lucent (AT&T) has the manuals!
In case this might help someone, I own two of these answering machines and can vouch that the user manual for the Lucent AS40 is the same as the AT&T 1715 and the Philips AD2735 is the same as the AT&T 1725. Here are the models that were produced during the joint venture:
AT&T/ Lucent 1715 = Lucent/ AT&T AS40
AT&T/ Lucent 1725 = Philips AD2735
AT&T/ Lucent 1717 = ?
AT&T/ Lucent 1815 = ?
AT&T/ Lucent 1825 = ?
AT&T/ Lucent 7625 = ?
AT&T/ Lucent 7630 = ?
Apr 09, 2009 | Lands Phones
I keep getting an f1 message and constant beeping from my oven
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Jan 30, 2009 | GE JVM1651 Microwave Oven
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Apr 01, 2008 | Uniden TRU9488 Phone
Change Answering Machine message in Lucent 1872 corded phone
Try just pressing down on the greeting button on the answering machine, you will hear the lady say "record greeting" and keep holdong down until you are finished recording the message. When you are done, remove your finger, done!
Nov 19, 2007 | Lands Phones
Lucent Digital Answering Machine Model 1715
If you search for an AT&T Digital Answering machine model 1715, you will be sent to a free service with an abreviated manual.
Oct 08, 2007 | Lands Phones
Lands Phones Logo
732 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
