Question about Jandy AQUALINK RS TELELINK KIT
PDA quit working and cannot override the system on control panel
I turned on my spa and light on with my PDA and shortly after the remote went out and it will not turn back on. Now my control panel on my pool will not override my PDA and my spa and light are the only things that work unless I put the control on Service or Time Out. How can I reset the board?
    Problem Solver:
  • 5 Answers
I had a problem simmular to yours When I changed my remote I had to also change my antena. Also make sure youd dip switch settings are set the same. between the antena & remote. The only reset that I know of is in the remot. Go to Menu then System Set UP. Then clear Memory. You Will loose all programs like, Dimming relays temp settings times for off & on. etc. I think if you have a intella flo motor you will have to reset it also.
Posted on Oct 05, 2009
The remote turns on but cant select any buttons replaced the batteries and reset the pool panel
turn off remote then turn off aqualink turn aqualink back on then turn on remote if still doesn't work check 4 pin red plug inside panel at top if ok check to see if wire to antenna cut if ok open antenna and see if green and red lights are blinking
Sep 14, 2015 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have a Coleman spa that works fine for about 15 minutes or so and then. The one pump stops and starts to surge on and off .the switch won't let me turn it off or on I've burned up one pump because
Do you have an auxiliary remote control panel?
Is it plugged into the cable of the main control topside panel?
If you do you have a remote panel, and it is not plugged into its own receptacle on the circuitboard, but onto the cable of the main top side panel, that remote panel may have a short. As it would override the ability for proper operation at the main panel. Disconnect that remote panel, it will not lessen the ability of spa operation, other than the convenience factor of having a remote panel, it should repair your problem.
Apr 08, 2015 | Pool & Spa
My jandy pda will not turn on after changing the batteries, any suggestions?
power aqualink system down all breakers turn off PDA then thurn aqualink back on then PDA should work if not need more info
Jun 29, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy screen backlight won't light
go into system set up find PDA and turn on the back light it will give 2 5 or 10 min choices
Oct 31, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy pda time keeps resetting back to default and the spa blower will turn on and off by itself
go to system set up see if programs if you have a 4 button spa remote disconnect and see if it goes away sometimes they get water in the wiring no programs are stored in the PDA
Jun 09, 2013 | Jandy Aqualink Pda Ps8 Wireless Handheld...
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy pda ps6 handheld just says "waiting" when you turn it on......it stays on like that until the pda shuts itself off......is there a way to fix it or a way to control my spa elsewhere
try turning off the aqualink and PDA then turn on the aqualink then PDA if same happens check the 4 pin red plug inside the top panel if plugged in check the wire to the antenna if not cut or loose open the antenna panel to see if red and green lights blinking if not check to see if you can change channels if you cannot get to work put system in service and you can control spa that way
Apr 13, 2011 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy AQUALINK RS TELELINK KIT  Logo
406 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
