Question about Philips Magnavox M61117 (DBM61117)
My Magnavox digital converter box shuts itself off every 5 minute
While i am watching T.V. my converter box has been turning itself off every 5 minutes for the last 4 days. The one year warranty is up. Where can I get it fixed and how much will it cost? Would it be better to buy a new one? Sometimes the converter box stays on and the T.V. will go to a black screen. Then when I turn the T.V. off and then back on, it comes back on for about 5 minutes and either the converter box or the T.V. will shut off again.Most of the time the converter box will shut down by itself and the T.V. screen will show "snow". Then I turn the converter box back on, and the T.V. comes back on again for 5 minutes and shuts off again. What is wrong?
  • Philips Master
  • 5,449 Answers
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Posted on Apr 05, 2017
  • MEHMET
    MEHMET Mar 11, 2018
    Sharp smart tv shut down by itself after 5 minutes if it rest a long time. Then shut down after some seconds.
    Tv used to shut down by itself after 30min when I bought it as used and i opened big holes on tv cover on behind. then the time delayed up to 3 hours.
    But now it shut down after 2 seconds if tv rest 10 hours the time is initially 5 min then 1-5 seconds.
    I changed 7 pieces capacitors but nothing changed. The power card number is HLL-4255WJ
    And it has 12v and 16v output, 12v is always constant. On 16v output, there is 19v when tv standby, when the tv is working it drop to 17volt.
    What is the problem?
epik559
  • 44 Answers
SOURCE: magnavox mwr20v6 turns itself off
The dry board is dead. or "power board."
Posted on Nov 25, 2007
ser71
  • 818 Answers
SOURCE: Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Posted on Mar 05, 2008
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
Posted on May 28, 2008
  • 608 Answers
SOURCE: Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
  • 608 Answers
SOURCE: magnavox 15inch lcd shuts itself off
Solutions?
Hope this helps
Magnavox converter box TB110MW9 shuts off repeatedly
Looks like you got a bad converter. I have the same kind and it is a pain that you can't use the remote to also control the TV. It will turn itself off after 2 hours by itself if you do not change the options, but the symptoms you describe are beyond consumer repair.
Do you still have the manual? There is a toll free number to contact them and ask for a replacement. If you do not have it I can provide it tomorrow. (I am not at home right now.) Of course you can only get one of the same converters.
Thanks for using Fixya.
Sep 02, 2009 | RCA Analog (RCA) to Digital (VGA)...
Why does my converter box turn itself on and shut itself off?
set your power down to off most boxes are set to turn off in 4 hours
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Digital converter box periodically turns on by itself
Did you ever find out why this happened? I have one, and it does the same thing. It makes me think Big Brother is watching me.
Apr 13, 2009 | Insignia Digital-to-Analog Converter for...
Converter box turns off by itself when watching tv.
Check the settings in the menu--many boxes have "power save" mode and will shut off after anywhere from 2-12 hours of inactivity. You should be able disable it or change it to a longer time.
Feb 20, 2009 | Insignia Digital-to-Analog Converter for...
Low Sound
Find out if there is a volume control for the converter box and adjust accordingly.
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Philips Magnavox M61117 (DBM61117) Logo
221 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
