Question about LG 42LH30 42 in. LCD TV
Lh300 sky box works with scart but wont work with hdmi cable just keeps saying no signal. new tv just received today
  • betty wood Oct 04, 2009
    yes clicked on the hdmi that i attched the cable to
    Sergeant:
  • 197 Answers
On your tv, have you selected the correct mode on your source button? eg, AV1, AV2 , PC, and HDMI
Posted on Oct 04, 2009
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
Trying to connect 46"samsung smart
200px-multiconnector-scart-chti.jpg magnify-clip.pngMulti-AV SCART adaptors with Input/Output signal switch (gold & nickel). A common misconception among game console owners is such connectors will allow RGB quality, while they are only CVBS and S-Videocompliant. THESE CAN BE USED FOR NON HD DEVICES SUCH AS YOUR DVD-VCR, AND SKYTOP BOX YOUR TV WILL HAVE AT LEAST 1 OF THE YELLOW WHITE RED COMPOSITE CONNECTION
May 05, 2011 | Computers & Internet
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Wired my surroundsound with scart to my sky box but only left & right speaker with sound
scart can only support 1x video signal and 1x L and 1x R in one direction
if you have a scart cable with more than 3 cinch connectors then you have one for two way, but you want to send 5 audio and 1 video channel one way from sky box to your receiver.
looking at the spec, your receiver does support a digital coaxial connection ( cinch orange) and a digital fibre connection
it also supports composite 5.1 analogue connection which is where are most likely already connected.
it does not seem to be a HDMI device.
if your sky box also has digital coax or fibre I recommend using one of these
alteratively if you wish to use analogue input on your receiver then ensure your topbox has corresponding 5.1 cinch connectors.
usually labelled (center, front,surround and possible also subwoofer)
if your receiver can generate 5.1 from 2.0 stereo (dolby pro-logic II) then ensure this setting is selected on your receiver.
not knowing what your sky box details are I can not say what is the best option. also check that your sky box is sending 5.1 signal out as some programmes may only be being sent in stereo so prologic will have to be activated to generate 5.1 from stereo.
Nov 13, 2009 | Onkyo HTR500 Receiver
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
I wonder if you could please help me with a problem. I have just had Sky installed at my home and am trying to tune my TV into the signal on my Humax LGB22DZT TV. It just will not pick up the Sky signal. I...
I would advise connecting your sky box to the TV with a scart cable or better still a HDMI cable & not the RF cable. The reasons for this sre
1.. You should get a much better quality of picture from Sky
2.. You will not need to tune in the TV just go to the AV or HDMI input source to obtain the sky channels.
Jul 11, 2009 | Televison & Video
No video signal on my tv fron the TX-SR605
IFF YOU ARE USEING HDMI FROM AMP TO TV SET HDMI OUT PUT ON IN AMP MENU, FIRST BY GOING TO SET UP MENU IN/OUT ASSIGN PRESS ENTER ,MONITOR OUT NOW ON AMP, PRESS ENTER TO SEE HDMI MNTR AND PRESS RIGHT ON ENTER BUTTON TO SWITCH ON.IFF YOU ARE NOT USEING HDMI TO TV LEAVE HDMI OFF AND PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP TO SELECT THE TYPE OF CABLE YOU ARE USEING FOR AUDIO,EG OPT1 OR2 COAX 1 OR 2,IFF YOU ARE USEING PHONO CABLES SELECT _ _ _ .MAKE SURE OUT PUT ON SKY IS SET TO RGB.
HOPE THIS HELPS.
CABLE GUY.
Mar 21, 2008 | Onkyo TX-SR605 Receiver
Sharp 32" LCD tv, screen going blank every few minutes.
Hide the remote from the set for awile and see if that magically "cures" this symptom....accordianman
Feb 27, 2008 | Televison & Video
LG 42LH30 42 in. LCD TV Logo
290 people viewed this question
