Question about Exercise & Fitness
I have an Everyoung treadmill that is not working. Did some basic t/s. Power to the switch is ok, switch is also good. Checked the two fuses (F1 and F2). Continuity through the safety switch is also good. There is no display on the control screen. Also checked for output at the dc termimals where the motor is connected - no voltage. Any other suggestions on what I can check?
  • 3,230 Answers
Well, Then you check the main power cord seems that the main power cord is shorted....if you not getting the power to the other end of the power cord.... try changing the power cord..
Good Luck!!
Thanks
Posted on Oct 04, 2009
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Why does dslite have no power?
Make sure the ribbon cables or the screens are plugged in. one for each screen and one for the touch screen (i think the touch screen is the one thats causing your problem) its small and comes out easily. please wright back if it works
Everyoung treadmill 86800
see the video attached. and lube the rollers bearing front+back.
God bless you
Oct 18, 2013 | Exercise & Fitness
Looking for owners manual for everyoung 86800F model
go for free download: www.fitness.manualsonline.com or www.manualsfactory.com or www.retrevo.com
sincerely. God bless you
May 07, 2012 | Exercise & Fitness
I have a 1991 Audi 100 and my power windows will not work. I have checked the fuses and they all are good. Can you tell me what to check next?
If the fuses are checked good.then other possibility is power window switch.If the switch is got short, then it will not let he power windows to function.Check the voltage at switch.It should be 12volts.If switch checked out ok, then it can be motor.If the motor gets short, then also same problem can occur.If motor checked out ok.Then its faulty connection between switch and motor.Get the wires checked between switch to motor.----------------
Apr 09, 2011 | Audi 100 Cars & Trucks
How do I lower my Everyoung 86800F treadmill from a vertical to horizontal position ?
This might be of a little help. My treadmill is not an everyoung but on the control panel it has two buttons which are used for adjusting the position. While i was searching for a solution on this i came across an individual whop has one for sale you could call him and find out if you are in the US here is a link to his advert.
http://fayar.craigslist.org/spo/2036394410.html
Hope this solution has been helpful?
Dec 10, 2010 | Exercise & Fitness
EverYoung 75900 needs to be reprogramed Display unit show F1 can you pls provide the code thanks Joanne Pekar
I have a problemwhen i start the ever young model 75900F
on screen F1
please send me solution
Nov 05, 2010 | Exercise & Fitness
Bodyguard T240 wont start
To use these instructions, you need to have a familiarity with electricity and a working knowledge of a voltage multimeter. With all of these tests, USE EXTREME CAUTION!!! Never let the voltage ground directly to any part of the treadmill or your leads ground while you are testing voltage.
1) To begin, set your volt meter to AC volts. We are going to trace the power from the wall outlet through the treadmill to see where it ends.
2) With the treadmill unplugged, test the wall outlet. You should have from 115 to 125 VAC. Optimally, you will have at least 120 VAC.
3) Follow the power leads from the power cord to the lead ends. With the treadmill unplugged, connect your meter to the lead ends. Plug the treadmill in and check your reading. It should be the same as your reading from the wall outlet.
4) Continue this process with the electrical system, following the leads, as they pass through, breakers, fuses, and the like.
5) Where the power flow ends is where your problem is. Sometimes it will be in a bad connection, sometimes it will be in a shorted breaker or blown fuse, at times it may be as simple as a safety switch not working properly, or it may be a major problem with a component.
6) In some cases, components work in tandem (i.e.- a controller may need a signal from the console computer to release voltage to the motor.
TESTING FUSES, BREAKERS, WIRING, AND SWITCHES
1) One of the most common problems with power outages is problems with fuses, breakers, wiring, or switches.
2) If your treadmill is equipped with a safety switch, set your volt meter to continuity. Touch your test leads together to make sure you are getting a closed circuit. With the treadmill unplugged, back the leads off the safety switch, usually near the upper display computer. With the safety key out, test the switch. It should be open. Push the safety key in. Your circuit should be closed. If this tests ok, move to the next step.
3) While testing for voltage, you can unplug your treadmill and test the fuses, breakers, and wiring harnesses. Sometimes a breaker may have shorted open and not tripped. Test these components individually. You want a closed circuit on all of them
Jul 10, 2010 | Bodyguard T240 Treadmill
Have the same problem with my Everyoung Treadmill EY88800K. Display was zapped with static and treadmill became inoperable. Great condition and hate to toss out. Any hope?
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Dec 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
209 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
