Question about QMark LFK304 Fan Forced Wall Heater - Perfect for Offices
I have a wall heater and there is a huming sound that goes on and then off it is off cuz its still hot weather what is this noise
    Sergeant:
  • 316 Answers
The fan.
Posted on Oct 04, 2009
Huming noise when I turn my steering wheel
sounds like you are low on power stearing fluid check level
May 07, 2015 | Ford E-Series Van Cars & Trucks
2008 Pontiac Grand Prix
It sounds like you have an air bubble in the heater core. Try parking front upward on the steepest hill you can find, and run the engine hot, with the heater control on full, for about 5 min. That may shift the bubble out.
Jun 27, 2014 | 2008 Pontiac Grand Prix
Ticking behind glovebox
Does it sound like the noise the turn signal makes? Does the noise change if you change the speed of the blower motor? Do all the function of the heater work (defrost, vent, floor, recirculate, fresh air, hot, cold)?
Nov 29, 2012 | 2003 Pontiac Sunfire
My aquastar 125b ng froze in cold weather and spewed water everywhere. when installes I was told it was ok to have this unit on outside wall. ... any suggestions
Generally speaking, tankless water heaters should not be installed on an outside wall, especially if they are masonary (which lose more heat to the outside) - regardless of what the installer told you. If the wall reaches & goes below the freezing point, so will the water pipes supplying the heater. However I am somewhat surprised that the heating element did not compensate, if indeed it was the heater that froze. I would recommend moving the heater to an interior wall if possible. You may also want to check the thermostat setting as well.
Dec 09, 2010 | Bosch Water Heaters AquaStar 125 series...
I have a Digital Sub 150 that has been working great. However, just recently it has a very loud hum after it ie turned on for about 3-4 minutes. The hum appears to be about 120Hz. I replaced the large...
It's a transistor that's getting warmed up and that causes the noise. You can get a Freezer spray by Servisol, to cool a suspect part down. If the noise goes after spraying you might have found the faulty part. To be certain, touch it with a hot soldering iron and it should start huming again.
Jan 27, 2010 | Audio Players & Recorders
Hot water heater does not light
burner and pilot assebly and orifaces need to be cleaned
Sep 16, 2009 | Fasco Bradford White Water Hot Heater...
Winding noise or vaccum leak from front of motor. no check engine light on. car runs good. just loud winding noise. wjen you turn the car off. noise sounds like it releases something. noise is lounder in...
A/C -Heater controls
Has you are aware the A/C Clutch compressor is engaged at all times when the defrost mode is turned on. Turn off all heater controls. If the noise is gone it will be either the Air conditioner compressor clutch bearing or possible the idler pulley bearing .
The Warden
Apr 16, 2009 | 2005 Ford Escape
Mysterious car noise
Check the oil first, if it is low it will cause a host of noises in the engine.
It sounds like that may be the problem you have
Nov 22, 2008 | 2005 Honda Civic
Broken temperature knob
IT SOUNDS LIKE WHEN TURNING THE KNOB IT WAS STIFF TO TURN THIS COULD BE CAUSED BY A SEIZED CABLE IF CABLE IS NOT SEIZED OPEN UP YOUR HOOD AND WHERE THE HEATER CABLE GOES THROUGH THE FIRE WALL THE CABLE SHOULD GO TO A FLAPPER WHICH IF PUSHED ONE WAY GIVES COLD AIR IF PUSHED THE OTHER WAY GIVES HOT AIR PUSH IN THE OPPOSITE DIRECTION TO WHAT IT IS NOW PUT A SMALL PAIR OF VISE GRIPS ON END OF CABLE SO IT CANT SLIP BACK TO COLD POSITION UNTIL YOU CAN GET A NEW KNOB IF CABLE IS SEIZED YOU WILL HAVE TO REPLACE CABLE+
Oct 08, 2008 | 1997 Volkswagen Jetta
QMark LFK304 Fan Forced Wall Heater - Perfect for Offices Logo
67 people viewed this question
Top QMark Heating & Cooling Experts
paulcarew
appman67
appman67
john h
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
