Peugeot 307 1.4 hdi cant find the electrical connection to fit my tuning chip to. Had the battery out but still cant see it.The instructions i got with it only show for the 2.0 hdi and that looks real easy to get to
  • 4 Answers
SOURCE: peugeot 307 2003 hdi... cant open my bonnet
The bonnet release is on the passenger side under the glovebox and pushes towards the footwell.
Posted on Mar 16, 2009
  • 215 Answers
SOURCE: "when do i change the cam belt on a peugeot 307 sw diesel"
usually you should do it for peugeot diesel at 122000 miles along with water pump and the tensioner roller that runs under the cambelt too. But to be on the safe side do it at 100000 and save the fortune.
It took me (DIY job) about 6-8 hours as i wanted to save 450 pounds.
Posted on Sep 04, 2009
SOURCE: peugeot 307 hdi 110 dash
ı have a peugeot307 in 80300km I DON'T KNOW exactly when take it to care ,brake.steering wheel,gearshift hydraulic,trigger set etc when will they change in what kilometers Can you help me? Thank you already
Posted on Nov 08, 2009
alicantecoli
  • 22326 Answers
SOURCE: peugeot 307 HDI airbag warning goes on and blleps
common fault defective centralita computer sorry forgotten name in english been in spain too long .When they get hot where car is left in hot sun the lights start blinking ,these cars and citreons suffer from this fault but not often,cure new centralita ,Once vehicle goes to the test and they see it then its about 2000euros to fix because it will not pass without the relevant paperwork and certificates from dealer,Best advice sell it quick before it costs a lot of money to fix
Posted on Jan 17, 2010
  • 4 Answers
SOURCE: can a speed sensor failing cause my Peugeot 307
an approved/competent peugeot dealer with peugeot diagnostic equipment can connect it to your vehicle and check the signals from the camshaft and crankshaft sensors. there shouldn't be any doubt about it. the engine control unit(ecu) needs both sensor readings(to identify which cylinder to inject fuel into)before it can start. a new cam sensor has a plastic nipple which should be in contact with the target plate when first fitted, this brakes off when the engine is started. it is used to ensure the correct gap between sensor and target plate. to large a gap and the sensor may not work correctly. once engine is started this info' is ignored by the ecu. the fuel pressure(measured by another sensor) can also be checked and is displayed on the equipment in "bars". 250bars of pressure are needed for engine to start. one of these (cam, crank, or fuel pressure signals) must be wrong if engine is not starting(assuming uncontaminated fuel). which one determines diagnostic path to be followed.
Posted on Mar 05, 2010
How to program key on peugeot 307 hdi 2001
put key in icnition turn on but don"t start engine,press door lock and hold for a few seconds,then turn off,key fob should now work,if not try again,also make sure you have the correct battery in key fob.
Nov 29, 2014 | 2005 Peugeot 307 HDi
Remove peugeot 307 harmonic balancer
A Peugeot toyota. , is this an engine swap , question?
post to Peugeot forum?
no year stated. 307 is just a body, and means zero.
2001 to 2008? WHICH ENGINE??????
1.4 L ET3 I4 (petrol)
1.6 L TU5 I4 (petrol)
1.6 L DV6 HDi I4 (diesel)
2.0 L EW10 I4 (diesel)
2.0 L DW10 HDi I4 (diesel)
Jan 30, 2014 | 2005 Toyota Tundra SR5
I want a picture of an engine undercover for a peugeot 307 hdi rapier
try ebay adds, or join peugeot public service box and see the diagram
Apr 15, 2013 | Peugeot Cars & Trucks
Peugeot 307 hdi 110. lights left on battery died, put a new battery in. car keeps turning but won't start. immobliser light stays on
the car is imobalised, try disconectint the earth from battery for 5 mins and reconect, car should start
Dec 12, 2012 | Cars & Trucks
I have a peugeot 307 hdi, the engine was changed r...
Hi - have the same problem - battery gone dead flat and now have no start except on spray??
May 20, 2010 | Cars & Trucks
Injector for peugeot 307 hdi 1.4''
yes, and there are four injectors in peugeot 307 hdi 1.4.
May 01, 2010 | 2005 Peugeot 405
Apr 15, 2009 | 2005 Peugeot 405
Peugeot 307 2003 hdi... cant open my bonnet
Mar 16, 2009 | 1991 Peugeot 405
Injectors
Injectors from the same ccm engine are most probably sounds same but to be on the safe side check not only the shape but code on the top of injector too. Because they are piezo effect injectors and set by the manufacture for a specific pressure for specific engine codes.
May 22, 2008 | 1990 Peugeot 405
Injectors
No, the size of the cars is different, so it wont work.
May 22, 2008 | 1989 Peugeot 405
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
