Question about Philips Magnavox 27MS343S 27" TV
My pillips lcd tv does not work on 75ohm cable inlet. signal is there because it works on my old tv
    Sergeant:
  • 197 Answers
Old tvs CRTs ( cathode ray tubes) pick up signal better than LCDs
So yes good quality satellite cable with better screening and low loss cable will be better, plus a new aeriel may do the trick.
Is your tuner in new LCD faulty though,? try it on your friends tv where you know the signal is fine.
Posted on Oct 04, 2009
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
Can I install an external antenna to this TV?
it is located next to the power plug and if you have more than one tv in the house you will need to use a splitter
Oct 16, 2013 | Sony KLV-S23A10 23 in. LCD HDTV
My Pillips 42" TV works
Is this a plasma TV? I have worked on several of these. Please provide the model number so I can better help you.
Mar 23, 2011 | Philips Televison & Video
JUST BOUGHT TV NO SIGNAL need help
Reset the tv and the cable box by unplug,replug it an hour later.Ur tv and cable box should reboot it self.The tv signal should return and work again.Not,call ur tv warrenty service for the repair.Tv under a year old,still have warrenty.
Jul 11, 2010 | Vizio VW32L 32 in. LCD HDTV
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
47 inch Olevia plugged directly into cable no box and will not program. All other old cable ready tv sets work without box
Diffrent tv,diffrent signals,deffrent frequencies.Talk to ur cable company for the box,to many pay tv signals in one area this day,that why need a box.
Nov 05, 2009 | Olevia LT42HVi 42 in. LCD Television
Lost some stations on my Sony lcd TV.
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV connection gets very good picture but VCR gets only bad ''grainey'' pic and bad sound. I used RF cables. Will using RCA cables solve the problem? Thanks Guy Daly dalyguy@hotmail.com
You could use 75ohm satalite cable for the RF cables it will give you better signal than the old style co-axial cables most people use. Simply put new co-axial plugs on the new cable and connect that. It will also cut down on electrical intereferance and noise if you use it right up to the antenna. Makes a hell of a difference if you are watching digital TV!
Jun 06, 2009 | Panasonic Televison & Video
Hello all;;;;;; i have a pioneer vsx-9500s,,,,the problem is i ran cable to my reciever so my fm radio will work but it doesn't,,,,,,,,i checked the cable on a tv and it worked ,,,,so i know the line is...
Nonsense. FM is included in MOST tv cable subscriptions- make sure your subscription includes this service. Do you have another receiver/tuner to test with?
Check all the connections between the cable entrance and your tuner; eliminate all splitters for testing. If you can get another tuner to work on your cable, it may be time to check into your tuner-
There is no difference in signal level between tv and fm- your receiver is not gonna burn up! If it has a 75-ohm cable input, use it!
Jan 04, 2009 | Pioneer VSX-D509S Receiver
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
Philips Magnavox 27MS343S 27" TV Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
