Question about RCA P52926 52" Rear Projection Television
My tv turned on and off by itself for a while and now it doesn't turn on at all but it has a little squeak at a regular interval
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
The tv will power off all by itself and then it may or may not turn back on. If it does turn on, it will be on for a short duration then shut off. The interval in between being on has become shorter over...
Try pressing the Menu button and selecting the Sleep timer. You should be able to disable it from the menu choices. The timer may have been activated during a storm or from a power surge. If this doesn't fix it try putting a piece of black tape or duct tape over the "IR eye" on the front of the panel - you may have a bulb or some other source of Infra red that's telling the TV to go to sleep.
Sep 10, 2011 | Vizio E370VL 37 in. LCD HDTV
Some times the tv would just turn off on its on and not turn back on
Several conditions predict the televisons experience. First, the tv has been set to auto power on at intervals also simialr as timer or alarm fucntionality. Refer to the user guide to ascertain the means to disengage the features to regular performance. Also, depening on the network televison estsblshed would require contacting support experts.
Feb 15, 2011 | Apex Digital LD3249 LCD TV
My rca tv turns off and on by itself
Is there a prankster nearby thast has a remote tuned to your set? As a young lad I used to play this trick on my neighbors daughter.
You should also investigate whether it is timed.. that is has a regular interval or time that it does happen. It could be another appliancwe doing this A/C ,Security system or some other eklectronic device. The dog has the remote under the cushion?
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | RCA P52960 52" Rear Projection Television
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung dlp shuts off at various intervals, new bulb, when you turn it on i can here a slight buzz,squeak type sound, makes me think ballast but then i read about the color wheel it does make the click but...
U have buzzing,squeaking.Some fading colors,black and white?Ur colors wheel is dead,it spinning off it axis.The Ballast is dead,u turn on the tv will making cliking noise,power shut down couples sec. after that.
Apr 30, 2010 | Televison & Video
Hotpoint dryer squeaks at regular intervals
Slow squeaking or scraping noises are often from the rear bearing behind the square panel, the rear bearing sleeve is inside the middle of the heater housing and the shaft part is attached to the back of the drum by a "C" clip which needs to be removed first.
The disassembly slideshow is here:
Slideshow
Sep 26, 2009 | Hotpoint TDL15 Electric Dryer
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
RCA P52926 52" Rear Projection Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
