Question about Refrigerators
I have an Adler-Barbour Super Cold Machine with a BD 50 compressor. It is not cooling and I suspect refrigerant loss. Problem is local folks don't have experience with marine refers. I need a copy of the repair and maintenance manual to know proper steps for someone to recharge it. Thanks, Steve
    President:
  • 1,167 Answers
Yes buddy it is refrigerant loss or the compressor is not working its very easy to refill but why has the gas gone these fridges are sealed for life with gas it shouldnt leak 1 bit check the condenser on the back and see if its warm also can you hear the compressor running get back to me
Posted on Oct 04, 2009
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
My ac doesn't blow cold
Can you hear the compressor starting? If so, suspect broken pipework and loss of refrigerant. If not, suspect loose wire to compressor or thermostat
Apr 19, 2012 | Dometic Rooftop RV Air Conditioner
Will not cool firge or feezer. Had a power loss then came back on here in San diego and firge/freezer will not cool now
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 10, 2011 | KitchenAid Architect KBFA25ERSS Stainless...
My Dad has whirpool Gladiator it only cools to 50 deg in the freezer . We unpluged it and let it set over night to see if it was a defrost problem.Compressor cycles and then shuts down @ 50 deg Still will...
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Leo Ponder
Aug 16, 2011 | Whirlpool Gladiator Refrigerator
Fridge freezer kfn 9755 ide - keeps losing temperature in both fridge and freezer, pushing super chill or super freeze buttons brings it back for a while. Engineer found no problem with the machine, but...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Miele Refrigerators
Roper model RT18BKXKQ02 - 5 years old. Cooling has been getting worse for the past 6 weeks. Finally quit altogether today. Fan runs but compressor does not. Suspect loss of refrigerant. Can you give me...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 04, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
UNIT RUNS BUT WANT COOL BELOW 50 DEGREES... COMPRESSOR IS RUNNING AND COLD LINE COLD ,HIGH PRESSURE LINE HOT BUT WILL NOT COOL BELOW 50 DEGREES.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Haier HSB03 Compact Refrigerator
Layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Nov 02, 2009 | Kenmore 50522 / 50524 Side by Side...
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
