Where may I purchace the charging harness for my Logitech model # F-0397A wireless headphones and transmiter? Jim corevare@sbcglobal.net
    Sergeant:
  • 316 Answers
Have you tried newegg.com
Posted on Oct 04, 2009
Insignia Wireless headphones Model NS-WHP314 own for 1 1/2 years.Left earphone no longer transmits sound. Connected to a Samsung TV. When I tap on earphone, it will transmit for only a minute & stop.
Take it to a professional to get it looked at.It could be a lose wire on the battery but even the smallest mistake and you will destroy it completely
Jun 19, 2016 | Insignia Audio Players & Recorders
Where do i find a manual for ZL-031D headphones
Zealot; Model:Zealot ZL-031; Type:Headphones (Headband) ; General Use:ComputerMobile PhoneMedia Player/Tablet; Function:With MicrophoneHi-FiGamingFM RadioVolume Control; Communication:Wireless 5GHz / 5.8GHz; Connectors:3.5mm; Memory Capacity:TF Card Support; Material:Polycarbonate; Color:WhiteBlackRedSilverPurpleBlue; Dimensions (cm) :7cm; Weight (kg) :0.4kg; Speaker Diameter:40mm; Speaker Sensitivity:-80dBm@.01%BER; Speaker Impendance:32; Speaker Frequency Response:2.4GHz; Plug Type:headband; Cable Length:1.5m; Max. Input Power:500mAh; Driver Type:Electret; Sound Channel:2.0; Input Voltage (V) :5V; Modulation Mode:Bottom Control; Transmitting Power:300mah-500mah; Power Supply:computer USB port DC5V; Working Voltage:3.5-4.1V; Battery:rechargeable lithium-ion polymer battery (3.7v 890mah)) ; Standby Time:300 hours; Talk Time:7 hours; Charge Time:7 hours
Nov 25, 2014 | Audio Players & Recorders
Can Sienna Van wireless earphones be used in other Sienna vans?
The wireless car headphones I have seen use infrared light to transmit/receive.You should be able to use any infrared wireless headphones,especially if they are from the same model vehicle.
Sep 18, 2013 | Car Audio & Video
My garmin 660 won't transmit audio through speakers or fm transmit. I go to audio output and it says that "Audio output can not be changed when using headphones" I can use it with headphones...
You have a problem with the headphone jack. Please see this link and read the section about BROKEN HEADPHONE JACK
http://www.sharc.net/gps_audio_repair.htm
Because there is a broken connection, your Nuvi thinks there are headphones connected at all times, so you wont be allowed to change the sound options. I've repaired this problem many times. Don't try it yourself, you risk damaging your Nuvi beyond repair.
- Jim
SHARCNET-USA
Jul 19, 2011 | Garmin Nuvi 660 GPS Receiver
Logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Dec 17, 2008 | Logitech FreePulse Wireless Consumer...
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Nov 25, 2008 | Logitech FreePulse Wireless Consumer...
Batteries
Logitech Customer Sales at 1-800-231-7717, Monday through Friday from 6am - 6pm PST.
cheers
Jan 10, 2008 | Logitech FreePulse Wireless Consumer...
Logitech Freepulse headphones on Ipod only playing on one side
Seems like you have a faulty transmitter unit. Try contacting logitech.
Sep 13, 2007 | Logitech FreePulse Wireless Consumer...
113 people viewed this question
 Grubhead
Grubhead
