when i put a dvd in the disk drive it only plays the audio. the video screen just says something like ''warning dont drive while watching video'' this happens all the time even if im in park.
You have to bypass the parking brake arrangement, which usually means just wiring that wire (it's the one the manufacturer wants you to have connected to the handbrake, Pioneer uses a lime green color) to the black ground wire. This works with most, but I have noticed that newer models work around that so you may need some sort of bypass toggle switch.
I have a 2wd, no sunroof SR5 sequoia and would like to install a dvd/video player on it.
Are there...
(More)
Are there units that fit into the last opening of the overhead console? Are the ones that are being installed aftermarket fitting in there or behind that overhead console? Any suggestions of ones that you have found to work would be greatly appreciated.
the dvd player in my valor its-720w system is not playing dvds. I can hear the sound of the dvd and...
(More)
the dvd player in my valor its-720w system is not playing dvds. I can hear the sound of the dvd and when i go to the eq settings i can see the picture through the eq screen, but it keeps saying for my safety the dvd has been disabled...
i got this head unit from a friend and it dont have the plug that plugs in the back of the head unit...
(More)
i got this head unit from a friend and it dont have the plug that plugs in the back of the head unit for the power and need to find where i can get it.
i have a kenwood KVT715dvd head unit,i exited my truck with the unit at low volume rentered and the...
(More)
i have a kenwood KVT715dvd head unit,i exited my truck with the unit at low volume rentered and the system was blaring and unable to lower volume or turn off,tried to reset unit and got no sound or response from controls
