Question about Audiovox WBT212 Headphones
Pin code I have a Samsung M510 phone. My headset is fully charged, Bluetooth is enabled. I have gone into trusted devices, add new, search. My cell recognizes the WBT212 and then asks for my numeric pin code. As fae as I know I do not have one provided. I entered my security pin for my phone and pressed OK, my phone then came back with "device not ready for pairing. I believe this is a good headset and would love to start using them. I know what Jensen speakers sound like and I'm anxious to start using my new toy. PLEASE help.
  • Anonymous Mar 21, 2009
    I want to pair a samsung and insignia buetooth headset. My cell found the Inssignia bluetooth and asked me for pin number.  Where can I foud the pin number?
    Sergeant:
  • 399 Answers
Is this the first time you are pairing two Bletooth devices ? Is the security pin for your Samsung phone '0000' ? Usually, the code you have to enter on your phone to pair it with a Bluetooth headset or headphones is '0000' (the number 'zero' 4 times), unless Jensen's Bluetooth headphones use a different pin.
Hope this helps.
zeceten@yahoo.com
Posted on Jan 07, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Audiovox Master
  • 1,001 Answers
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
What is the pin # for a motorola H555 bluetooth
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code.
This pin code will be 0000..
Please RATE THIS SOLLUTION
RNJ VINODKUMAR
Sep 27, 2009 | Motorola Mobility H500 Wireless Headset
Headset not found
This will vary depending on the model of your phone. First off, you need to ensure that you are using a bluetooth enabled phone.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
Note - I am taking into consideration that your headset is fine.
Thanks.
Jun 11, 2009 | Motorola Mobility HS820 Consumer Headset
Reprogramming bluetooth
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
J can't use the bluetooth headset wep210
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Im trying to pair my verizon cell phone to my motoral headset
5) Select the Motorola device and click add
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth won't connect
follow the steps below:
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 24, 2008 | Motorola Mobility H550 - Bluetooth Headset...
I need the access code to pair it to my cell phone.
Follow the steps below:
So - 0000 (four zeroes)
hope this helps
Chris (ziraffa)
Nov 20, 2008 | Plantronics Explorer 220 Bluetooth Headset...
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
Audiovox WBT212 Headphones Logo
573 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
