Question about Epson Stylus CX6600 All-In-One InkJet Printer
After changing the ink cartridge the printing is too light.
  • 749 Answers
SOURCE: Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Posted on Oct 28, 2007
  • 26 Answers
SOURCE: Yellow Ink Won't Print
what is the yellow ink cartrage level is it empty
Posted on Mar 08, 2008
sherlyn c
  • 134 Answers
SOURCE: changing ink cartridge
If you are using an rx700, open the cartridge covers infront of the printer. Press in to release it then pull it out of its slot.
Posted on May 22, 2009
  • 208 Answers
SOURCE: Changing a cartridge low in ink (less than 5%)
Please download the user's manual here: http://files.support.epson.com/pdf/r300__/r300__u1.pdf. The instruction is on page 90. You should be able to open the cartridge cover if you follow the instruction.
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: we changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Posted on Sep 18, 2009
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
My canon pixma 180 has orange alarm light and reads check ink cartridge,. it won't print. it printed yesterday.
One or both print cartridges are defective.Look under the "check ink" what message come.If it's BLK change black cartridge, if it's CLR change the color cartridge.If BLK and CLR change both cartridges.
Nov 05, 2009 | Canon PIXMA MP180 All-In-One InkJet...
We changed the ink and the red light and green
Hope this helps
Then
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson stylus cx4400 printer
This for the CX5400 which is similar with its menu system:
Using the Control Panel Follow the steps below to replace an ink cartridge.
r_1.gif Make sure this product is on and the On light is not flashing.
When the ink is low:
Press one of the Menu buttons until Change Cartridge appears on the LCD panel, and then press the fontx1.gif Color Copy button. The ink cartridges move to the replacement position. r_3.gif Make sure that the document cover is closed, and then raise the scanner unit.
a8101037.gif r_space.gif r_caut.gif Caution: r_space.gif r_space.gif
  • Do not raise the scanner unit with the document cover opened.
  • Do not move the print head by hand. Doing so may damage this product.
  • Do not start replacing the ink cartridge before the print head stops.
r_4.gif For best results, shake a new ink cartridge four or five times, then remove it from its the package.
a8102006.gif r_5.gif Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of this product and dispose of it properly. Do not take the used cartridge apart or try to refill it.
a8101049.gif r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Be careful when you are handling used ink cartridges, as there may be some ink around the ink supply port. If ink gets on your skin, wash the area thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If discomfort or vision problems remain after thorough flushing, see a doctor immediately.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Be sure to always install an ink cartridge into this product immediately following the removal of an old ink cartridge. If the ink cartridge is not installed promptly, the print head may dry out rendering it unable to print.
r_6.gif Place the ink cartridge vertically into the cartridge holder. Push the ink cartridge down until it clicks into place.
a8101051.gif If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7. r_7.gif Lower the scanner unit.
a8101039.gif The print head moves and ink charging begins. The On light flashes while ink charging is in progress. When the On light stops flashing, ink charging is completed.
Jun 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
