Question about Indesit K344GX Gas Kitchen Range
Indesit K3G21XG oven not staying lit without knob pushed in.
We've had this cooker for a few years and it has worked faultlessly up until now. The oven does not have any kind of electronic ignition system and you have to light it manually by turning the oven knob and holding it in whilst holding a lighter or match by the hole on the bottom/front of the oven. Usually 6 seconds or so will do the job.
Alas now the oven lights without a problem but no matter how long you hold the knob in as soon as it is released the oven burner goes out.
Any advice would be much appreciated as we really don't have the money to replace the cookerand it has been kept in great condition.
5 Suggested Answers
dazzle37us
  • 17 Answers
SOURCE: my cooker will not stay alight
check if the oven holes are not blocked by some dust or dirt, then try puting it on again.
Posted on Aug 03, 2009
  • 1462 Answers
SOURCE: Grill element was corroded and
did you reset the clock after you switched on - i suspect you have it on automatic
Posted on Sep 18, 2008
SOURCE: Oven doesn't stay on
You need a new thermocouple. This is a safety device which holds a small gas valve open when a flame is detected. It stops unburnt gas building up in the oven. I would seek professional advice from a gas safe registered engineer. Check www.gassafe.co.uk for an engineer in your area. Good Luck
Posted on Jun 09, 2009
  • 2600 Answers
SOURCE: my indesit gas cookers igniters keep clicking, i
yes its possable for that to happen try replacing the switch
Posted on Jan 21, 2010
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
My oven wont stay on but grill still ok but they work off same knob
it could be the thermocouple, you can get uiversal thermocoulpe from mmost plumbers merchants , b and q etc.fairly easy to fit ,any probs drdrop me a line
Dec 06, 2012 | Indesit Gas Cooker Spark Ingniter Unit...
When you first light the pilot works fine after cooker heats up it may cycle a few times and the pilot goes out and then when you try to relight it will only stay lit while the pilot button is being...
Hi there. Try cleaning the thermopile, it must be free of soot or any other form of dirt, the pilot flame should be of good quality, as well as the gas pressure.
Regards.
Aug 02, 2011 | Imperial IFST25 Deep Fryer
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
My cooker will not stay alight
Aug 03, 2009 | Indesit K344GX Gas Kitchen Range
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Indesit gas cooker, odd smell
Indesit Cucina cooker
My tenant is complaining of burnt metal or burnt rubber smells when the oven is hot, it is perfectly clean and only two years old
Nov 26, 2008 | Indesit K344GX Gas Kitchen Range
Cooker
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
Apr 01, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Indesit K344GX Gas Kitchen Range Logo
953 people viewed this question
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
Paul Carew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
