Question about Frigidaire Ovens
MY OVEN DOES NOT GET HOT, THE BROILER WORKS AND
MY OVEN DOES NOT GET HOT, THE BROILER WORKS AND SO DO THE BURNERS.
  • 557 Answers
If we are talking about an electric oven. The oven coil is probably bad. Easy to test remove it and check for continuity. If it shows open cicuit them the coil is burned out.
Posted on Oct 04, 2009
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Our oven does not heat-the broiler and the range do work, but the oven doesn't get hot. Is this a pilot problem-and if so, how do we re-light it?
Im sure its not a piolot.. if your broiler and upper burners have ignitors the oven will also. Most of the time the ignitor goes bad, you need a volt meter to check if you have power to it if you do its bad.
Mar 22, 2010 | GE Ovens
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Broiler on top works but oven wont ignite
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
It might be possible that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
If you want to see a line drawing and a parts list showing the ignitor(s), go to searspartsdirect.com and enter in the model number of your oven and click on the links shown.
Hope this helps and best regards!
Jul 31, 2009 | Ovens
Oven glow plug on but oven wont light , dosnt get hot , top burners work fine. broiler also dosnt work . oven about 13 yrs old
if ignitor glows and the burner does not fire within 30-60 seconds it is weak (not drawing 3.5 amps or higher) and should be replaced. Hope this helps,please rate my solution
Jun 26, 2009 | GE JGRP17 Gas Single Oven
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
116 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
