Question about Dell Computers & Internet
I would like to replace one CD drive from me Dell Dimension 2400 System service tag DXY0631. I can't find the screws that will allow me to remove the section that holds the 2 CD drives in the chassis so I can replace one of these CD drives with a DVD drive? The computer is 7 years old!
  • Dell Master
  • 3,051 Answers
Hello there:
on some of these dell's like mine i need to remove the front cover to acess 2 screws that hold the whole assembly onto the chasis then it will come out and there are 2 screws on the opposite side of the drive that is holding in the cd rom and in my other dell i ned to remove the front panel and there is a tab that i need to press and thedrive slides out the front of the computer so please try both oif these and see what helps you out ok?
best regards michael
Posted on Oct 04, 2009
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
Hard drive boot failure
what is the error message? If operating system could not find, try you original windows installation CD, during you boot from the CD there is a repair option, follow the wizard to complete.
Sep 03, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 fan replacement
it is very easy just remove the plastic cover from the fan & lose the screw and replace the fan with the new one
Feb 27, 2012 | Dell Dimension 2400 PC Desktop
How to install a dvd and cd player in a Dimension 2400
I actually had this case.
When you want to install a DVD and a CD player into a Dimension 2400, you will need to do two things.
1. On the DVD and CD player you will need to install a screw that has an insert on the end of it so it will not go in all the way. You will need to search for those screws from a hardware store. If you can't, just contact dell and they can send you out those screws.
The two screws closest to the front of the case receive them. The other one that you can access closest to the power supply receives just the ordinary screw that you use to secure a hard drive.
2. Once you have done this, just set the master and slave on the appropriate drives and connect them with a ribbon cable on the secondary IDE controller.
Just make sure to have at least a 350 Watt Power supply. A 300 Watt one will work, but it won't give you much room for expansion.
Aug 06, 2009 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 & figure out what sata chipset it is compatible with...im trying to learn how to burn games for xbox 360 but not real computer savvy
On the back of your dell is a service tag. Copy it down and go to ww.dell.com and Support and drivers, input your service tag and it will give you the original configuration of hardware and software installed on your computer.
Jul 30, 2009 | Dell Dimension 2400 PC Desktop
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.
http://reviews.cnet.com/desktops/dell-dimension-2400-pentium/4507-3118_7-30824846.html?tag=mncol;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=89&name=DVD-Burners&
Cheers!
Mike
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400
Open your dell, remove the cd drive backwards, the cd driver has two green rails where it glides on. Those rails you ned to put back if you replace it with onother driver.
Good luck to you
Dec 18, 2008 | Dell Dimension 2400 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
