Question about KitchenAid Food Mixers
I have a k45ss that died while mixing. - KitchenAid Food Mixers
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
The main cause of these mixers failing is the carbon brushes, which are located in the left and right sides of the unit. remove the two plugs on either side and visually inspect that these are not worn. also make sure they go back in correctly because they will only work one way. after inspecting these you can take off the back of the unit and inspect the wiring all around the main board, burned wires are frequent as well. if you see no black or burned wires it is most likely your board which is a part number 416232. hope this helps
Thanks
Posted on Oct 11, 2009
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
My kg25h7x varies the mixing speed on its own
The Kitchenaid uses a centrifugal switch to maintain a constant speed. This must be sticking to cause this. You mixer will need to be disassembled and inspected.
Jul 03, 2012 | KitchenAid K45SS Classic Stand Mixer
My KitchenAid mixer clicks when I mix bread dough and any other thick batters. How do i fix it?
Make sure your dough hook isn't bent.... or your bowl doesn't have a dent in it.... and make sure the bowl is properly seated and secure.
Aug 29, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid classic mixer,mixing head comes down to far
flip head up; and, there is a adjust screw underneath. turn screw out ccw to raise head.
Jun 06, 2010 | KitchenAid K45SS Classic Stand Mixer
Leaks oil when mixing. the area where you put the beaters leaks a small amount of oil only when mixing.
The grease inside has liquefied instead of being a paste. This can happen by over heating the mixer, keeping near a heat source or a bad gasket. I suggest getting it repacked with grease and replacing the gasket before you start to ruin the gears.
Also the grease although not something you'd consider edible is food safe.
Nov 16, 2009 | KitchenAid K45SS Classic Stand Mixer
MY KITCHENAID MIXER MODEL # KSM5 TURNS ON BUT THE BEATERS WONT TURN. I MIXED UP SOME PIZZA DOUGH AND GUESS I BROKE SOME GEARS OR SOMETHING. PLEASE HELP!!!!!!!!! THANK YOU
The most common part to fail in this mixer is the worm gear:
http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
Oct 31, 2009 | KitchenAid K45SS Classic Stand Mixer
K45ss mixer works fine except when whipping cream there are small black specs appearing in the bowl that probably have gone unnoticed with darker mixtures. I suspect some type of oil leak
Yes this is probably a oil leak. it can come from two possible location one of which can come from the transmission gasket that goes around the mixers center seem, if this is broken, worn or improperly seated it will need replacement. part number for the transmission gasket is 4162324. another possible location is around the cirrcular mixing gear at the front of the machine. if the seal inside the unit are damaged or worn this can cause oil to leak striaght down into the very food you are preparing. part number for the seals are 3180163. there are 4 of them, and they would require taking apart the whole unit. hope this helps.
Thanks
Sep 27, 2009 | KitchenAid K45SS Classic Stand Mixer
Mixing bowl is jammed into the base and won't come out
you may have the old style frame which is why the bowl jammed old bowls are no longer avaible you may need to purchace a new mixer
Dec 10, 2008 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
69 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
