Question about Sony KP-61HS10 61" Rear Projection Television
Remote stopped work for my kp-61hs10
The set and remote were working fine... went to bed next day the remote did not turn the tv on... tried the buttons on the front of the set... the tv turned on changed channels/volume... worked fine... but the remote would not function... still controlled the cable the dvd and surround sound... so changed batteries and tried again... and the remote still does not work the tv...
i have a universal remote as well as the remote that came with the set... and nothing from either....
please help
  • Anonymous Jan 06, 2008
    My remote just stop working. changed the batteries, tried to re-code the remote nothing works.
  • badboz13 Mar 18, 2008
    same problem ??
  • 53 Answers
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Posted on Mar 25, 2008
Sanyo DP26640 Remote not working
It could be that the remote died. Happens. Is it sending signal to set? If not, it is bogus. If it is, then set's receiver circuits are fubar.
Try also cleaning the contacts for on/off button.
Apr 12, 2017 | Sanyo DP26649 26 in. TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Went to be with the set working, woke with the
I believe this problem is identical to the fellow who had the power led comes on but no video. Follow the instructions on that one solved. You also have a bad eeprom. If you have more questions, as not finding the problem earlier in this page. Let me know.....It is a simple solution.
Jun 25, 2009 | Philips Magnavox 27MS343S 27" TV
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
148 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
