Question about Canon PIXMA iP90 Mobile Printer
How to replace canon print head printer ip90 - Canon PIXMA iP90 Mobile Printer
    President:
  • 2,306 Answers
After you open the cover and the carriage comes to the center for new ink, you press the resume button for a few seconds and the carriage will go to the printhead changing position. You don't want to ever force the printhead to move. Hope you didn't break something already. Sorry for the stupid help.
Posted on Oct 13, 2009
  • 3 Answers
Open the blue inside cover with power on, as though you will change the cartridges, then force the carriage ever so slightly right, so in the near left corner you see a grey plastic tab, push that and allow the small frame to lift up, when its clear of the body you can let go of the carriage and then lift the head out - with or without the cartridges in, WARNING!, make sure you reseat the frame properly before the blue cover goes back down or it will foul as the carriage retreats back to its cleaning station
Posted on Oct 11, 2009
  • 76 Answers
SOURCE: Figuring how to install new print head in my Canon iP90 printer
when you open the top cover, the carriage unit will mvoe to the middle of the unit. Once it is there hold the inks and move a bit to the left so you can see a grey lever. then the printhead and the inks will come up together. remove inks and replace head.
This should work for you
Posted on Oct 20, 2008
Soulvisitor
  • 1113 Answers
SOURCE: print head for canon ip90
yes
6d8b426.jpg http://www.softwareforless.com/findspecs.asp?partid=52912B
Posted on Dec 29, 2007
The important point is moving the head to the left, or sliding it left or right, so you can actually SEE the LEVER. It is hidden otherwise and what appears to be the obvious lever on the top is the wrong lever. If you have pressed the correct lever the unit removes very easily. If it is hard and you cannot make progress chances are you have not found the correct LEVER!
Posted on May 04, 2009
  • 71 Answers
SOURCE: Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Posted on Jun 02, 2009
komguy
  • 2306 Answers
SOURCE: Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Posted on Jul 21, 2009
We are trying to get our iP90 printer to print. We have cleaned the print head, replaced both black & color ink. We have done a deep cleaning several times, cleaned with alchol & cotton q-tip....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Apr 04, 2011 | Canon PIXMA iP90 Mobile Printer
I have PIXMA iP90 printer but having problem of not printing blank test,I mean if i change the text colour to blue or any different colout it prints but not with black ink
This seems to be a comon problem with canon printers the black head is either dirty or needs to be replaced. canon should look into this
to clean heads use rubbing alcohol, cotton swab
put some rubbing alcohol on the cotton swab and gently rub the black portion of the head until it is clean
Mar 06, 2011 | Canon PIXMA iP90 Mobile Printer
My Canon IP90 printer in printing blank paper
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaces.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new injet printer.
Jan 16, 2011 | Canon PIXMA iP90 InkJet Printer
My canon ip90 printer cartridges is stuck to the right of the printer. And the light keep flashing orange 5 times. Can someone please help me fix it.
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
May 29, 2010 | Canon PIXMA iP90 Mobile Printer
Its asking to install new color but have done this and it's still not working i've replaced both with the same problem
I have the same problem with my IP90. I send it to Canon Service Center in Philippines and they replaced the print head which cost almost the whole printer assembly. After about 6 months (seldom used) it has the same problem and the service center wanted to replace the print head again. I opted to get a new one IP100. My usage is still not so frequent but it is still working after more than a year now. The IP90 is not so good design when it comes to parts replacement. The parts are in modules. No piece-part sold.
Dec 18, 2009 | Canon PIXMA iP90 Mobile Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
  2. Wipe it clean,
Hope this helps.
Jun 02, 2009 | Canon PIXMA iP90 Mobile Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Print Head
After opening the purple cover, the printer head will move to the center. There should be a gray tab on the left side of the forward facing opening (about the middle of lower cartridge). Gently push printer head to the right (1/4 to 1/2 inch) and a gray slanted tab will appear from behind housing. lift this tab and a metal lock will pop up. Tilt lock back and the printer head should be lying loose in its cradle.
Apr 11, 2008 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
3,091 people viewed this question
old marine
old marine
