Question about Vtech V.Flash Home Edutainment Learning System Console
Where can I find an AV output cord for my vtech flash?
How u get the dvd to play on the tv
Hello
Refer to the DVD plyaers' user manual about which RF channel is its output has been set for. If your TV has an AV in put facioty, you can connect the dVD to TV with an AV cord, and select the input to tV to AV. Image of AV cord is attached.
Mar 12, 2012 | Fisher PC-6520 20" TV
The VCR works fine but I only get audio with the DVD
  • Are you using an AV cord between your VCR and TV or a standard coax? If you are using a standard coax then first make sure the tape is functioning properly. Next try a new coax and if the problem persist there might be an issue with the coax output/input on the VCR or TV itself.
  • If you are using the AV inputs (red,white and yellow) you want to remember that the red and white are for audio and the yellow is for video. So in this case you want to
  1. Make sure the tape is functioning correct. Old tapes that have seen their better days will produce audio but no video and vice versa.
  2. Check the connection of your yellow AV input (audio). Make sure it goes from the same output on your VCR to the same input on your TV as the audio cords are running to.
  3. If this checks out then try a different audio cord and see if this fixes it.
  4. If not then try using a different output on the VCR and input on the TV all together.
  5. At this point it is possible one of the AV audio jacks are bad either on the VCR or on the TV.
Regards, Tony
Apr 22, 2011 | Apex Digital ADV3800 DVD Player/VCR
My ps3 was recently connected to a hdmi cord at my friends house now im back home nd i plug the av cords in and nothing is coming up its still connected to the hdmi
Hello. Sounds like you need to adjust the video output setting back to component. Go to settings, display settings, then video output setting. you may need to do this under an hdmi connection in order to see it. Once you change it to component then it will switch over to a standard AV connection.
Apr 05, 2011 | Sony Playstation 3 (PS3) Console
My dog chewed the power cord on my ps3 while it was on and it triped the breaker in my house ,i got a new power cord but now the ps3 powers up but cant get the hdmi cable to work to tv
It may be possible that he has caused a power outage that disabled your HDMI output. It is a common problem, both HDMI and AV outputs will go out.
Can you get a display with AV cords (if you haven't tried, get them ready)
You may be faced with a problem that will cause you to use AV or Component cables. (recommended if HDMI output is out)
Try to reset your settings.
Plug in both AV and HDMI cables.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go. Make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options.
Try 1.
If you are able to get the AV cables to work with this method, try setting your HDMI up as you did before.
If you cannot get HDMI to work, then your output has gone out. You must use the AV/Component cables.
If you get no display at all but the system appears to be responding normally (outside of the display) then:
You have what is commonly known as the "Green light of Death."
It is when your system powers on and acts normally but no display. Your GPU (graphics chip) has cracked or become damaged and will need to be sent in to SONY. You can try a 3rd party technician, but this repair has a very very low success rate.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Need av cord to use please help
Should be able to find one ebay pretty cheap.
Dec 27, 2010 | Vtech V.Flash Home Edutainment Learning...
I was having trouble with my component AV cable. I went to purchase a new cable, HDAV component cable and connected the xbox. I had an image for a short time and now do not. Please help!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
My xbox360 has 3 flashing red and will not respond to anything except turning the unit on off and opening and shutting
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Jun 30, 2008 | Video Game Consoles & Games
My xbox 360 has one flashing red light, and it keeps showing me the code E 74
Jun 29, 2008 | Video Game Consoles & Games
Vtech V.Flash Home Edutainment Learning System Console Logo
155 people viewed this question
Top Vtech Video Game Consoles & Games Experts
James Wishart
Are you a Vtech Video Game Console and Game Expert? Answer questions, earn points and help others
