Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Black screen I turned on my tv today and the screen is black with rolling red and/or blue lines. If it is a picture tube are those typically expensive as this tv is almost 5 years old and I am wondering if I should buy a new one or have this one repaired? Thank you.
    Genius:
  • 1,153 Answers
Sounds like convergence, you can get more info at ctechnicians.com
Posted on Dec 22, 2007
Screen fades from normal at start-up to blue in about 10 seconds, TV stays on, display goes black, sound still on, and red light on front blinks 5 times
These sets kp51ws500 had issues with bad picture tubes----this set uses a Red,Green and blue picture tube.
The tubes are only available on a rebuild basis and very expensive. There is one thing that requires no parts replaced you can try: here are the instructions:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SONY WITH BLUE SCREEN PROBLEM:
You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Dec 05, 2009 | Sony KP-51WS500 51" Rear Projection...
Lines, then no picture, then turns off
Remove Front panel look for screen/focus controls adjust them you have R/G/B for each tube ,you have screen drive controls as well as focus Start with red turn green and blue off adjust each one untill you have a black/white picture, If screen drives are to high TV will turn off.Also if STK ICs are bad TV will not come on there is a blue capacitor behind hori output Transistor that also burns out CK it as well.LET me know if any of this has helped you or if you need more information.
Aug 06, 2009 | Sony KP-57HW40 57" Rear Projection...
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Hazy, washed out picture on Magnavox 51mp6100d
Remove back see if you can get to tubes top lenses clean all 3 from dirt/dust/ After cleaning off lenses there is a black control box has 3 controls on top 3 on bottom these are to adjust each tube R-G-B Tubes screen/ focus adjust one tube at a time--- Like to adjust red turn g,b.screen drive off turn red up adjust focus to a clear picture ,then green same and blue If you turn screen up to much it will either shut off or you will see Drive lines adjust back down.OK after doing this turn color off in menu adjust all 3 screen controls untill you have Black and white picture try to adjust as close as you can to get bl/wt picture when that is done now turn color on and you should have alot better picture.
Dec 19, 2008 | Televison & Video
Please help
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Jun 14, 2008 | RCA D52W15 TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Television has audio but a black screen
Bad technicians always say picture tube problem when the TV has black screen with sound. This a false statement and in some cases techniciacns use this to scare the owner or the charge a hefty amount. The truth is that picture tube outlast most component in the TV. If it will fail, it is gradual like the colors will fade or one or several color will be missing. This condition is the degration of the filament in the gun (CRT tv has three -Red, green , blue) I started to repair TV in the early 80's and only in one occasion that the Tube fail and it is a crack in the neck. For black screen with sound, the most common cause is the HV supply problem / Horizontal section. This can be caused by many things, like flyback transformer failure, horizontal outout transistor, horizontal drive, etc. For the cost-depends on where you are, in some countries labor is dirt cheap, in other ountries the parts are expensive.
May 22, 2007 | Mitsubishi CS-40505 TV
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
