Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
I need the mannual of the "Saeco Vienna digital" coffe machine.
I need to descale the machine and have lost the mannual. Please email me the same. mkgbapuji@yahoo.com
    President:
  • 1,618 Answers
Press the menu button then using the up/down arrows keys select descale, then place a large container under the wand and slowly open the knob, follow instructions on screen when it says finished close knob, clean tank and fill with fresh water then open knob to rinse.
Posted on Oct 05, 2009
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Our Saeco Vienna Deluxe stopped dispensing; we decalcified with decalicification product purchased at Wms Sonoma but it did not fix the problem. At first it took a very long time to get a cup (which is why...
Have you tried to clean the screen on the brew unit? If yes then try this remove the brew unit, and you will see the white plastic valve, gently lift the little lever to see if water flows out, if it does then problem is in the brew unit. If not then try another descale using scalekleen.
Nov 30, 2009 | Saeco Vienna De Luxe Espresso Machine
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
How do I descale my Saeco Vienna Deluxe?
Purchase the Saeco descaler. Mix solution accordingly. Pour into water tank. Run a cappucino cup full of water through the wand. Wait about 20 minute and repeat. Do this until all the water is gone in the tank. (Don't run all the water at once!). Rinse water tank well. FIll with clean water and run through the wand. I do this twice just to be sure I have gotten all the chemical out.
Aug 15, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna digital not steaming !!
Hi
If you get water through the wand, you may have a thermal fuse that is blown or the element in the steam boiler is gone. Let me know if you need one.
May 26, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco odeo giro and the red squiggly light
This is the descaling indicator.
If it flashing your machine needs descaling.
Feb 22, 2009 | Saeco Vienna De Luxe Espresso Machine
How do I turn off the "descale now" warning on my Saeco Vienna Deluxe espresso machine?
After performing the descale, use the menu buttons to get to descale and set to reset.
Dec 05, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco coffe maker doesn't work
Thank you for your concern! I drove it over to place nearby that fixes these machines in Los Angeles. That way, I can avoid costly shipping charges!
May 24, 2008 | Saeco Vienna Digital Coffee Maker,...
How to descale machine
you can download and print a manual for your Saeco here
ttp://www.manualnguide.com/download/manual-guide/saeco-odea-go-instruction-manual.html
Dec 11, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
120 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
