Question about Sanyo DS31590 31" TV
SANYO DS31590 TELEVISION
IS THIS UNIT EQUIPPED FOR DIGITAL RECEPTION ? IE " BUILT-IN DIGITAL TUNER.' ' DTV OR ATSC'
  • Anonymous Jan 02, 2008
    I don't have a remote control, the TV is stuck in video mode.
    Is there a master re-set?
    Is the TV locked?
    How can I fix this.
  • Anonymous Jan 22, 2008
    remote not working an is new replacement from sanyo
For the stuck in video problem just go buy a generic "universal" remote and set it up to control the TV. they aren't expensive at all for a basic unit,and they can be used to control your DVD player as well.
Posted on Feb 18, 2008
  • 373 Answers
No digital tuner inside. Will have to have a converter box in Feb 2009 for digital: Search "the fcc on digital tv transmission" on the internet for useful information on the upcoming digital age..
Posted on Dec 30, 2007
How do I get my 7" widescreen lcd tv with atsc tuner to show channel numbers?
ATSC Digital (VIRTUAL!) Channel NUMBERS vs Actual Channel ...
www.avsforum.com/.../1260172-atsc-digital-virtual-channel-numbers-vs...
Jul 2, 2010 - 4 posts - ‎4 authors
Then came ATSC tuners and digital - [I was about 20 minutes into .... *SHOULD*display the SAME VIRTUAL CHANNEL NUMBER when tuned ... iView-3500STB Tuner & DVR Owners Thread - AVS ...
Mar 30, 2013
OVER-THE-AIR DIGITAL TELEVISION RECEPTION ...
Dec 3, 2005
More results from www.avsforum.com
Jan 13, 2016 | Televison & Video
Is the tuner built-in ATSC, or NTSC?
Your tv tuner is set to function on both NTSC and ATSC. See below for the reference
NTSC (National Television System Committee) is the analog television broadcasting standard used widely in North America. It is referred to as a 525-line standard, but actually displays only 480 lines. NTSC is to be replaced with new DTV (Digital TV) standards in the coming years.
ATSC (Advanced Television Standards Committee) creates the technical standards for the US digital television system (DTV). These standards are expected to be used in most new televisions, as the US television system shifts from analog to digital.
Nov 10, 2010 | Toshiba 57H84 57" Rear Projection...
Does my model have a built in tuner please Sanyo   LCD32xR8DA  television as the manual was lost this is all the info i have .    flat panel television
Yes your unit has a built in tuner:
Tuner Tuner Type HD Digital
Included Tuner Style Inbuilt
Pal Reception System B/G check this for more info
Sep 11, 2009 | Televison & Video
Digitial reception for casio 980
You won't. Because the unit isn't likely to have an coaxial external cable input, there is no simple way to achieve this. Full-size sets not equipped for digital signals can accept the down-converted signal from a converter box that receives the digital signal and converts it to NTSC standards for older sets. Direct reception of the new signal requires an ATSC tuner and there is no way to provide that for your hand-held. It would be possible to use the output of a converter box clipped onto the antenna of your Casio and see the channels the converter box can receive but your hand-held wouldn't be very portable anymore. Sorry-
Aug 20, 2009 | Casio TV-980 2.3 in. Handheld Television
Does this model have a built-in QAM tuner?
Yes it does.
  • Includes built-in ATSC/QAM/NTSC tuner for off-air HDTV and SD (standard-definition) reception
  • Accepts high-definition 1080i, 720p, and 480p signals from DTV set-top receivers and progressive-scan DVD players
  • Side-panel A/V hookups and controls allow easy connection with a camcorder, gaming console, or other device
  • Aug 15, 2009 | Samsung DynaFlat TX-P2775H 27" TV
    I have a sylvania 42 plasma tv and I would like to know which digital tv tuner I would use for this tv
    You didn't include any model number so we can't do much for you.
    Check your your owner's manual to see if your set is equipped with an ATSC tuner. If it is, you need no external tuner. If it isn't, any will do but I like the Zinwell ZAT-970.
    Mar 10, 2009 | Sanyo DP42746 42 in. Plasma Television
    Get Dtv with my 37MF321D
    This TV does not have built ATSC/RF Tuner.
    I have this same model TV, the analog reception is snowy even with outside aerial. I have to get the Govt, Set box converter and the picture is now perfect! Apply for the Govt Digital TV converter Box and you will enjoy it
    Feb 01, 2009 | Philips 37MF321D 37 in. LCD Television
    Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
    Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
    unfortunately you have a
    • Analog TV Tuner NTSC
    and
    • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
    You need a tv that has this:
    Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
    So Sorry, the tuner is not Digital.
    Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
    How do i convert my dtv-5801 to the new free digital air waves
    My information indicates that the DTV-5801 has a NTSC (analog TV) tuner built in bot not and ATSC (digital tuner). It does have HDTV inputs to which an external tuner can be connected. For Off-Air Digital TV, add an HDTV (ATSC High Definition tunner) and you are set to go. Do not buy the DTV converters, they have down converters built in and only deliver SD to the outputs.
    May 26, 2008 | Runco DTV-5801 58 in. Rear Projection...
    Sanyo DS31590 and converter box
    I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
    If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
    If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
    If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
    Good Luck
    Feb 29, 2008 | Sanyo DS31590 31" TV
    Sanyo DS31590 31" TV Logo
    99 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
