Question about Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656
Cub cadet wont engage blades to cut grassmower iz rtz 50 zero turn tried to move the wires around and checked the 20 amp fuse no shorts. was cutting fine i just stopped to dump the bagger. any help would be greatly appreciated
  • chitownbob45
    chitownbob45 May 11, 2010
    did the belt break?
  • 148 Answers
Try this:
With the engine turned OFF, unplug the wire connector at the PTO clutch, and use an alternate 12 volt DC power source and some alligator clips to manually power-up the clutch. If a firm, crispy "Click" is heard each time you "power-on / power-off" the clutch, then safety switches on the tractor are the most likely suspects.
If no firm, crispy "Click" is heard, your PTO clutch needs to be replaced.
On the right-hand side of THIS page, type in (without spaces) RZT50 and you will be given a list to choose your EXACT machine & part number.
Special Note:
If your part number description says to refer to "Service Advisory ...(blah blah)" then you will need to call a servicing dealership for the proper replacement part number.
Hope this helps.
Posted on Oct 05, 2009
The 20 amp fuse blows when i engage the pto. cub cadet 1045 20 hp
Pto cluch is shorted to ground
unplug the pto to isolate the pto from the circut,
Does the fuse still blow ?
use a ohm meter to test the plug at the pto
Test each side of plug to pto body or ground if meter goes to zero the cluch is shorted , and is not fixable (sealed unit)
you will have to by a new one I'll say around 50 to 75 dollars
Aug 24, 2014 | Garden
My cub cadet Rtz 50 cuts out and backfires when the PTO is engaged. It runs fine when not engaged
sounds like it needs a tune up.
It doesn't like to run under load.
Is air filter clean?
May 01, 2014 | Garden
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
I HAVE A CUB CADET 50 INCH CUT ZERO TURN, WHEN YOU PULL THE PTO SWITCH TO ENGAGE THE BLADES THE BATTERY WILL DISCHARGE.
Most likely a short. You have to look in the area where engage switch gets blades going. You will find a cut wire or wires that are touching metal. This will kill a battery very quick. Fix wire , tie up wire so this doesn't happen again, and off you go. GOOD LUCK.
Jun 16, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a 50" cut
Most likely you have a faulty seat switch. Replacing it should solve your problem but visually check the wiring to the switch first. Regards Phil.
Apr 12, 2011 | Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656 Logo
670 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
