Question about RTO Hera 4-Level Touch Dimmer 110 Volt
Hera Touch Dimmer not working
Stopped working this week. About six years old.
  • 736 Answers
If what you are refering to is a touch lamp where you touch the base and the lamp changes brightness ... if it just stays on full brightness all the time .. then thats a shorted triac .. that a transistor like part inside the unit .. they frequently go bad when a light bulb burns out ... when you see a bulb burn out you will someitmes notice a very bright flash ... thats the tungstun filiment evaporating and making a highly conductive atmosphere for a second .. huge amount of current can flow for this brief period .. that often damages solid state devices like yours ... unless you are handy with these kinds of repairs then you might just want to purchase a new touch dimmer replacement circuit ... usually available at large hardware stores ..
Posted on Oct 04, 2009
H.t.c HERA-110 unlock phone
You can get the unlock code for your HTC Hera 110 phone from WickedUnlock.com and unlock your phone from Network lock easily.
Apr 08, 2014 | HTC Touch Pro Smartphone
Vornado fan repair
i need help wit my westinghouse 52' ceiling fan. i have the lights wrking and the fan, but the dimmer wont work. i have the blue coming from fan connected the black coming from wall,and the white coming from fan connected to red coming from wall,then black coming from fan connected to another red coming from wall. now i need help how to make the dimmer work, is my connection wrong?
Jul 28, 2013 | Dryers
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 26, 2013 | Electrical Supplies
Nuvi 650 touch screen stopped working
My Garmin Nuvi 650 would boot up and load maps, but I could not enter my access code. Screen would not respond. Turned off & on a number of times, but still same problem. This occurred on first use after upgrading the maps. Thinking it may have overheated on the dashboard of my truck, I held the device in front of the air conditioner vent for about five minutes to cool it down. When I then turned it on, it worked fine. For the rest of my 3-week vacation, I kept it cool & out of the sun when it was not turned on. No problems after that.
Jul 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Dsi touch screen stopped working only a week old can you do a hard reset on this
Try going to the system settings.
Then find the button that says touch screen.
You will then get to recollaborate the touch screen.
This should work.
Good luck! :)
Dec 29, 2009 | Nintendo DSi Black Console
Hoover turbo cyclonic only 12 weeks old stopped working while cleaning. I was using the hand tool and after about 3 minutes it just stopped and will not turn back on.
try changing the fuse in your plug ( uk ) if this fails to fix it , have it repaired under warranty
print-icon.gifPrint/Download
Warranty The Platinum Collection Lightweight Bagged Upright plus Portable Canister warranty covers parts and service of the cleaner for six years.
As a member of the Hoover Platinum Collection, the Platinum Collection Lightweight Bagged Upright warranty gives the owner access to the exclusive Platinum Collection member services line for the best in customer service.
TTI Floor Care North America
7005 Cochran Road
Glenwillow, OH 44139
1-877-MY-PLTNM
Nov 15, 2009 | Vacuums
3-way dimmer dead
It could be a loose connection, and it could be a loose connection on the OTHER 3-way switch across the room. Also, verify that the dimmer is rated for the fixture(s): add together the wattage of each individual light bulb that the dimmer controls and make sure that the dimmer has a higher wattage rating. If it isn't, you might have burned up your dimmer (and risked an electrical fire). Hope this helps!
Aug 31, 2009 | Leviton Decora Light Dimmer Switch
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
RTO Hera 4-Level Touch Dimmer 110 Volt Logo
489 people viewed this question
Top RTO Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
