Question about Toshiba 40H80 40" Rear Projection Television
I have a Toshiba 40H80 rear projection TV with sound but no picture. Menu will not display, nor DVD or cable TV.
  • 65 Answers
SOURCE: accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Posted on Dec 09, 2006
SOURCE: Toshiba 51H83 51 in. Rear Projection pisture issue
I have a wild guess. I have the same tv and channel 72 is the proper channel to watch tv on. I don't know why, but maybe try channel 72 instead of the usual channel 3. Good luck, maybe a quick fix, maybe not!
Posted on Nov 27, 2007
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
Posted on Jan 31, 2008
  • 301 Answers
SOURCE: Toshiba 42WH36P rear projection TV has wavy lines
the problem is going to be a bad NEXT HYPER UNIT module. this is the digital scan card in the tv. try using the componenet inputs and if the tv works ok then you know that the HYPER UNIT is the problem. the reapir process for a "do-it-yourselfer" is too involved and would recommend a serivce center for this repair.
Posted on Feb 22, 2008
  • 108 Answers
SOURCE: toshiba 42h82 - "broken" picture
the "scan converter module" is located directly behind the board where your inputs are in the back of the set. That should repair the problem.
Posted on Jan 08, 2009
Toshiba 40H80 TV - looking for original remote.
You can buy them at any of these sites:
http://www.toshiba.newremotecontrol.com/catalog_item.php?catnum=23306458
http://www.remotes.com/store/toshiba/40h80.html
or ebay
Aug 17, 2009 | Televison & Video
Toshiba 40H80 Rear Projection TV flickering & blacked out
try converence board going out on your unit usally about 300 bucks to fix ok thx nick
Feb 08, 2008 | Toshiba 40H80 40" Rear Projection...
Can't get toshiba vcr to work with toshiba TTP-61H95 and dvd
please make sure the cable from ur vcr is attach at V-OUT...and cable from vcr that attach to dvd is V-IN...to make sure vcr is displayed at your tv, unplugged cable from vcr-to-dvd to from vcr(V-OUT)-to-tv(V-IN)...
Jan 10, 2009 | Toshiba TP61H95 61" Rear Projection...
Sound, No Picture
The only thing you can do is to unplug the tv for 30 min. Then turn it back on and see if that fixed it. If not call a repair man, you are most likely missing a power supply voltage or deflection voltage.
May 26, 2008 | Toshiba 40H80 40" Rear Projection...
40H80 Toshiba Rear Projection TV
it sounds as if it is solder related, bur hard to say for sure. You ay need a service manual to actually trouble shootthe power supply and opeating circuits. I will post a lnk where you can get a service manual emailed to you
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 40H80 40" Rear Projection...
TOSHIBA 40H80 projection TV - no sound / no picture
it could be, that would be the first thing i would do to rule out I would first check for loose connections on the board.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
No Picture - No Sound - Pilot lite OK - hear speakers 'blip' when turned on
Toshiba did have a problem with a protection ic that would fail. It is possible that this is the problem. But some trouble shooting will need to be done buy a repair shop.
Toshiba Rearprojector TV
you didnt say if the set was working?? if its not I would first try the power regulator IC in the power supply It will start with an STR#####.. This goes bad alot in these sets. Good luck
Apr 17, 2006 | Toshiba 40H80 40" Rear Projection...
40H80 Problem TV will not switch to non antenna inputs
Sounds like you have a bad tuner. It is not uncommon for solder joints to deteriorate over a period of time and loose continuity. If you are handy with a soldering iron, you can try to fix it yourself but I really recommend leaving it to a professional.
Dec 06, 2005 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
