Question about Frigidaire GLGF377 Gas Kitchen Range
Oven will not heat
Oven does not heat up, but broiler still functions properly
  • 3 more comments
  • Anonymous Dec 23, 2007
    Broiler works but the oven won't heat up.
  • lockdoc Jan 01, 2008
    oven does not heat but broiler will come on
  • Anonymous Jun 16, 2008
    The oven does not heat.
  • fixer dad Oct 26, 2008
    How do you replace stove bottom heating element on maytag electric stove.
  • diysfr Jan 03, 2009
    This problem is for a gas range and your best solution here is for an electric range...inappropriate.
    Problem Solver:
  • 6 Answers
Most likely, your lower heating element has failed and needs to be replaced.
This is a simple step-by-step procedure...
1. Turn off the power to the oven at the breaker panel. Or slide the oven ahead and reach behind to unplug the power cord.
2. Take out the two screws holding the element bracket in place. These will be on the back wall of the oven. They are usually hex head or phillips screws.
3. Carefully pull the element toward you a little bit until you see the two wires behind it. Unscrew the wire leads and remove the bad heating element.
4. Handle the new element carefully while you attach the wire leads to it with the old screws. Don't stretch the wires any more than you have to.
5. Line up the new element while tucking the wires back in place. Be sure not to pinch the wires between the bracket and the back wall.
6. Fasten the bracket screws, making sure they're tight.
7. Restore power to the appliance and start your oven to check if the new element heats up.
A few things to remember...
You are working with high voltage! Be sure the power is off or the oven is unplugged!
If you find one of the wires has come off the old element, simply reconnect and check your oven. Your old element may work again and you will not need to purchase a new one.
In removing any of the screws mentioned above, note that they may be difficult to lossen due to years of exposure to heat. Don't give up, they will eventually loosen.
Your new element may have some oil or other gunk on it due to the manufacturing process. Once it begins to heat, it may start to smoke. Don't panic! Any residue will eventually burn away and the smoke will cease from then on.
Good Luck!
Posted on Mar 20, 2008
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc.
Apr 18, 2017 | Whirlpool Kitchen Ranges
Gas oven/broiler won't light
If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 04, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
The broiler and the oven will not heat up/ the oven was on, working fine, starting losing temp. The gas was still on.
Hi Satk78
Since both broiler and bake are affected then the cause is common. The first to consider would be the gas supply - make sure the regulator from the supply is functioning properly
The safety valve is the most likely problem. If a knock on it(safety valve) cause the oven to work better, then, change the safety valve.
Aug 26, 2009 | Tappan Ovens
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler and ovev filaments dont heat ES510 OVEN
i'm sorry to say, but it sounds like you need a control board:(
Jan 01, 2009 | Kitchen Ranges
Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
Frigidaire GLGF377 Gas Kitchen Range Logo
241 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
