Question about SmartDisk FireLite 40 GB Hard Drive
I dropped my fireite and now it won't open. Can
I dropped my fireite and now it won't open. Can it be repaired? The device makes a humming and clicking sound when I plug it into my compluter.
  • 3,153 Answers
There is a VERY strong chance you killed it. real hard drives dont like any form of violent movement such as you describe.
Try some of the hints below and see if yo get lucky.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 04, 2009
Why won't Convertible top won't go down 08 Sebring
the humming is the motor trying to open roof , the windows dropping is a normal part of the operation , without seeing the vehicle it's difficult to be exact but unless there is a latch /lever that has to be pulled prior to pressing the switch i'd recommend getting a auto electrician to look at it , could just be a relay not powering up enough keep me posted if you wish
Jun 07, 2014 | 2004 Chrysler Sebring
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
My dryer won't turn on and it makes a humming
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Kenmore 600 6965 Electric Dryer
Humming bird is in our house and cannot get out, stays near ceiling.
open the windows and doors,, try assisting it to go in the right direction with a broom very slowly, if it won't drop down low enough to find its way out,, use a light sheet to trap it in a corner, and wrap it up , open the sheet outside, and it will fly away ( you can tape broom handles to the edges of the sheet so you can reach up high enough to corner it .)
Aug 10, 2011 | Garden
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Jun 16, 2011 | Kenmore Dryers
Printer won't turn on and AC Power Adapter plug is making a humming noise.
hi
if the AC adapter is humming, refrain (stop) from using it !
the adapter is physically damaged and the internal transformer has been dropped several times to make such a noise.
you will have to purchase a new AC adapter, p/n should be and it should cost about $10-$15
ADP-25FB
pleae issue 4 thumbs up ... thanks for using FIXYA
May 10, 2011 | Lexmark X5150 All-In-One InkJet Printer
My B/A 735 speakers were working fine then a hum started for a day or 2 & they totally quit working. Power supply is OK & other speakers work on my computer. Where can I get the control board...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Mar 11, 2011 | Boston Acoustics BA735 Computer Speakers
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Humming sound
In my professional opinion, it sounds like you have a shorted relay or other defective component on your control circuit board, which is actually made by Samsung. We regularly repair these control panel assemblies nationwide for $32.50, so the problem can certainly be fixed economically. Looking at typical microwave wiring shows it has to be the cooking relay or a device that drives that relay. Since it stops when you open the door, we can say the door switches are certainly doing their job.
Oct 26, 2006 | GE JVM1850 1000 Watts Microwave Oven
SmartDisk FireLite 40 GB Hard Drive Logo
118 people viewed this question
Top SmartDisk Computers & Internet Experts
terminalcon
Dennis Crouse
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
