Paper sized mis match - Office Equipment & Supplies
2 Suggested Answers
  • 58 Answers
SOURCE: paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
I am using HP P4515n on network enviorenment and I am facing a problem while giving print to printer, after giving print I have to press ok or c button to take print out result ? Please help me to...
The paper size or type that you are requesting to be printed from your computer does not exactly match what the HP printer thinks it has loaded in the paper tray. An example would be your are trying to print a document on 81/2X11 plain paper and the HP is programmed for 81/2X11 letterhead paper. Or you have tray1 selected and tray 2 has the paper installed. In short when I see this problem it is usually because there is a mis-match between what the computer is printing to, and what the HP printer thinks it has. Just check you paper tray settings both when you are printing the job and check the paper tray settings on the printer to make sure there is no issue.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 08, 2011 | HP P4515n LaserJet Printer
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
We don't get print from Ricoh after formatting the
try and print a test page from the driver and make sure paper is set corectly
Oct 25, 2009 | Ricoh Aficio 2016 All-In-One Laser Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
Paper tray default issues
Dec 23, 2008 | Ricoh Aficio SP C410DN Laser Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Konica minolta
How about this, if you look what paper tray are avaible from the display pannel, is there a matching size paper tray or is the tray you are trying to use another size then lets say LTR. Is it a different size, if so you may have paper jamed behind the paper tray causing a different paper size, if so remove the jamed paper..... Also, the other suggestion are good as well.
Aug 06, 2008 | Konica Minolta DiALTA Di200 Copier
79 people viewed this question
jasbo
jasbo
