Question about Sony Cyber-shot DSC-W90 Digital Camera
Lens will not fully extend; receiving message to power off then back on. Still not working despite multiple attempts. Sony cyber shot dsc w90
PEye2000
  • 10 Answers
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Posted on Mar 26, 2009
  • 586 Answers
SOURCE: SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Posted on Jun 14, 2009
  • 10 Answers
SOURCE: Change language display on Sony Cyber-shot DSC-W220
try under the settings menu
Posted on Jul 19, 2009
virtualhost
  • 2185 Answers
SOURCE: NEED DOWNLOAD FOR SONY CYBER-SHOT DSC-W80, I LOST
Would you like to open your pictures from your Sony Cybershot to your computer? Your cybershot cam is usually plug and play so you dont need a software for that. All you do is to plug in your camera to your computer's usb port using the usb cable. When the computer detected the new usb device, open a Windows Explorer. Right click your windows Start button, and choose Explore. From the list of Drives from the left, you need to find the Drive letter associated with your camera. Just click on that and it will show you the files on the right. The pictures are located somewhere inside those folders. You just need to click and drag them to your computer's local drive.
Should you have any questions, please let me know. Good luck!
Posted on Nov 13, 2009
BillB-SA
  • 2761 Answers
SOURCE: hello, my cyber-shot DSC-P73 will not stay on
If the camera hs recently been dropped it may have lens damage that is preventing the camera from powering up. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 01, 2009
Testimonial: "Thank you BillB-SA, i have cleaned as suggested so can only assume lens damage by dropping by persons unknown. Oh woe is me!"
Sony DSC-W70 digital camera - Lens attempts to open when pressing the power button but fails with a message to turn off and back on again. Bought a new battery and still does the same thing. Sometimes...
That's a common problem on Cybershot cameras, happened to me twice, the solution is to get it to a camera shop for repair.
The cause could be dirt or a malfunction on the lens extending mechanism.
Mar 10, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
IAM TRYING TO TURN ON MY SONY DSC-W90 CAMERA BUT DOST NOT TURN ON AND LENCE FREQUNLY TRY TO OPEN CLOSE AND I RECEIVED MESSAGE ON LCD DISPLY TRUN THE POWER OFF AND ON AGAIN , EVEN I REMOVED AND FIX BATTRY...
The error message is due to the lens issue. the lens might have stuck due to moisture condensation or dust. It may require service to resolve the issue.
If you wish to resolve it yourself, you may use a soft cloth to clear the dust by manually pulling out the lens part..
If it doen't help, it may require opening the Camera
Jan 22, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Have a Sony Cybershot DSC-W90 camera. After turning camera on, get message stating "turn power off and on again." Same message over and over again.
For these few days i have saw users asked this problem here again and again. Come to see my article in my blog, Maybe it will help: turn the power off and on again maybe something will helpful
Jan 04, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera reset for w90 and w200 sony
If camera is DSC-W90 and DSC-W200, go to camera menu and select Initialize -> OK
That will Reset camera to factory default settings.
Feb 23, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Sony cyber shot dsc-w90
If you've tried whacking it, maybe you didn't whack hard enough. get a hammer. whack it about five times.
Aug 07, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
I had the same problem, I gently pried open the black windows of the shutter with my index finger nail, and applied very gentle pressure (pulling outward) while I pressed the power button. THEN... the whole zoom assembly moved EVER SO SLIGHTLY. So, I repeated the exact same process, with a little bit of pressure... and voila... the lens assembly opened fully and I was able to take pictures.
Jan 14, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Dsc-w90
you will need to pack this camera as if you were packing a pack of ciggs or a deck of cards. this will cause it to resync with the lens.
Sep 02, 2007 | Sony Cyber-shot DSC-W90 Digital Camera
Sony Cyber Shot DSC-L1 Digital Camera
Sounds like a jammed lens block assy.Does lens make any attempt to open??.Did camera get a knock or fall.Not much you can do but send for repair,Would advise get estimate before proceeding with repair.,
May 20, 2007 | Sony Cyber-Shot DSC-L1 Digital Camera
W1 lens not extending properly
Lens is damaged. not economic to repair
Dec 12, 2006 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-shot  DSC-W90 Digital Camera Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
