Question about Acer 22" X223w LCD Monitor
My desktop icons all have lines above them that are distorting the picture
This happened to me after updating Adobe Flash.
A system restore got rid of them, but they have now recurred after a Windows update.
Posted on Nov 11, 2009
    Problem Solver:
  • 8 Answers
Monitor connections must not only be plugged in, but also screwed firmly into place. then press the screen refresh button..that should do it
Posted on Oct 14, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Sony model KDL32L5000 has a black horizontal line across the display. above the line picture is fine, below the line display is distorted... any ideas?
Faulty vertical deflection section. check the yoke vertical winding. maybe its cure from service mode. search online how to apply service mode of you tv brand, model and board chassis number.
Aug 17, 2014 | Televison & Video
Icons on desktop distorted can not read or move them as they should be
What do you mean mixed together?
Try this: Right Click on a empty space on the desktop then select Arrange Icons By. Then select either Auto Arrange or Align to Grid.
Why did you have someone remotely fooling with your system? If the above steps do not solve it, you can always try to roll your system back to before you had iYogi changing things. You can do a System Restore which will allow you to select a date and time before you started having problems. System Restore does not delete your data, documents, music, pictures, videos or programs unless the program was installed after the Restore Point (date and time) you selected.
To start System Restore click Start/Programs/Accessories/System Tools/System Restore then you can choose the date and time (Restore Point) that you want to roll back to. You can see additional date and times other than the one original displayed.
May 13, 2012 | Computers & Internet
Dont have the model number as i am at work however it is an older model projection tv. I think it is 65in looks like the one above. However i came home turned the tv and the picture is distorted. the...
Picture distortion in your rear projection TV is because of failure of convergence out ICs that need to be replaced.
Qualified TV tech will fix it under $150 or $200 and if your are good in part soldering in circuit boards and have electronics knowledge then can replace by yourself.
Required ICs can be purchased from Part Store.
Oct 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture distortion on desktop monitor
ok when upower up the computer pres F8 key thwn go to enable vga mode.then set resulution settings to 1024*768.
Dec 29, 2008 | Apple iMac G5 Desktop
The positioning of my desktop's imageis still distorted despite running the easy tune display wizard and my using the auto tune keys on the side of the monitor.
Use the manual methods on your monitor (horizontal and vertical size and position), not the auto tune and see if you can get it to improve.
Try using a different desktop picture as well.
Right click on the desktop where there are no icons, and change the picture. Also, play with Stretch/Center/Tile - stretch will distort a file if it doesn't exactly match your screen settings.
Jul 17, 2008 | Gateway Computers & Internet
Sony Vaio PCG SR33
Sounds like 3.3V line is not up to par so to say.. Integrated VRAM for the Graphics on this model? Everything is tied into eveything and if you are getting distorted Icons/graphics I'd look here first but some digi-snaps of the screen would also help. Sonys are a pain generally and I'm not well versed on this model. Any other info on the web besides Update this/that? Does BIOS apear normal?
Talk soon..
Feb 06, 2008 | Computers & Internet
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Black horizontal lines across bottom 1/3 of screen
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Aug 23, 2007 | GE 27GT722 27" TV
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Acer 22" X223w LCD Monitor Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
