Question about HP Officejet Pro L7680 All-In-One Printer
Fax and scanner not working
Fax feeder not working properly
2 Suggested Answers
tommya300
  • 724 Answers
SOURCE: Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Posted on Jul 31, 2009
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Feeder scanner stop after 1cm scan/fax
You need to clean the rollers inside the feed section, use an alcohol wipe.. or something like methylated spirits and a rag..
Oct 16, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Samsung scx-4521f lines on feeder scan
Youll find that the most common problem with fax machines is that the scanner head that the paper passes over actually gets gritty and dirty. Remember it only takes a spek sitting in there.
Try a damp cloth (not to much Water) and wipe down the sensor reader, It will take a little bit of trial and error but mainly this is the common problem. also try wiping down all the wheels and rollers that the paper runs over as well. Otherwise it could be the recieval end that has a dirty paper feed wheel.
Sometimes it is also common that the internal scanner/sensor reader wears out and needs replacement.
IF this is the case its generally cheaper to buy another fax. Hopefully the above helps for you so you dont have to buy another one
Cheers
Steve
Apr 01, 2009 | Office Equipment & Supplies
Fax doesnt work right
Either a section of your l.e.d. array is dead (lights that light up under the sheet feeder when scanning), or the scanner glass under the sheet feeder is VERY dirty, but it's unlikely that it would be that contaminated. You can try cleaning it, but my money is on the LED's
Mar 31, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
HP 5030 do not send fax properly
Open the document feeder and clean the scanner glass.
Dec 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Jamming of paper using the Automatic Document Feeder
You may have a really tiny paper jam. You need to open up unit to get access to feeder properly. Use a torch, jams can be so small you can miss them. cheers lilacgerry
Jan 28, 2008 | Brother MFC 6800 All-In-One Laser Printer
HP Officejet Pro L7680 All-In-One Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
